this is another wireguard performance thread, i have a strange problem when connecting from my laptop wireguard peer, to my rb5009 at the office.
I use my laptop which is connect with ethernet cable on a Chateau lte18 using lte connection (~100mbps down / 70~ mbps up)
I connect with wireguard to my office using also the 0.0.0.0/0 on allowed addresses in order to “take” my office public IP and route all my laptop’s traffic through the office.
My office has a connection with 200mbps down and 20mbps up (point to point Public IP connection through VDSL technology)
MTU on wireguard interface at rb5009 is 1420.
My download speed from my laptop when connected on wireguard is 1mbps down and 19 mbps upload.
I can’t find why i have so poor performance on down speeds while the upload is fine.
I thought it was mtu issue but tried several values without any change, down speed is very low compared to the up speed.
when i check the wireguard interface on rb5009 i get many tx errors around 1617 errors at the moment, while rx errors are 0.
Below is my mikrotik config:
interface bridge
add admin-mac=DC:2C:6E:3B:C7:89 auto-mac=no comment=defconf name=bridge.LAN \
priority=0x1000
/interface wireguard
add listen-port=51820 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool1 ranges=10.0.0.100-10.0.0.199
add address-pool=dhcp_pool1 interface=bridge.LAN lease-time=1w1d name=dhcp1
/queue type
set 0 kind=sfq
add kind=sfq name=qos
/queue tree
add bucket-size=0.01 max-limit=190M name=DOWN parent=bridge.LAN queue=default
add name="1. VOIP" packet-mark=VOIP parent=DOWN priority=1 queue=default
add name="2. DNS" packet-mark=DNS parent=DOWN priority=2 queue=default
add name="3. ACK" packet-mark=ACK parent=DOWN priority=3 queue=default
add name="4. UDP" packet-mark=UDP parent=DOWN priority=3 queue=default
add name="5. ICMP" packet-mark=ICMP parent=DOWN priority=4 queue=default
add name="6. HTTP" packet-mark=HTTP parent=DOWN priority=5 queue=default
add name="7. HTTP_BIG" packet-mark=HTTP_BIG parent=DOWN priority=6 queue=\
default
add name="8. QUIC" packet-mark=QUIC parent=DOWN priority=7 queue=default
add name="9. OTHER" packet-mark=OTHER parent=DOWN queue=default
add bucket-size=0.01 max-limit=20M name=UP parent=ether1 queue=default
add name="1. VOIP_" packet-mark=VOIP parent=UP priority=1 queue=default
add name="2. DNS_" packet-mark=DNS parent=UP priority=2 queue=default
add name="3. ACK_" packet-mark=ACK parent=UP priority=3 queue=default
add name="4. UDP_" packet-mark=UDP parent=UP priority=3 queue=default
add name="5. ICMP_" packet-mark=ICMP parent=UP priority=4 queue=default
add name="6. HTTP_" packet-mark=HTTP parent=UP priority=5 queue=default
add name="7. HTTP_BIG_" packet-mark=HTTP_BIG parent=UP priority=6 queue=\
default
add name="8. QUIC_" packet-mark=QUIC parent=UP priority=7 queue=default
add name="9. OTHER_" packet-mark=OTHER parent=UP queue=default
add bridge=bridge.LAN comment=defconf interface=ether3
add bridge=bridge.LAN comment=defconf interface=ether4
add bridge=bridge.LAN comment=defconf interface=ether5
add bridge=bridge.LAN comment=defconf interface=ether6
add bridge=bridge.LAN comment=defconf interface=ether7
add bridge=bridge.LAN comment=defconf interface=ether8
add bridge=bridge.LAN comment=defconf interface=sfp-sfpplus1
/ip settings
set tcp-syncookies=yes
/ipv6 settings
set disable-ipv6=yes
add comment=defconf interface=bridge.LAN list=LAN
add interface=ether2 list=WAN
add interface=wireguard1 list=LAN
/interface wireguard peers
add allowed-address=172.16.10.2/32 interface=wireguard1 \
public-key="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
add allowed-address=172.16.10.3/32 interface=wireguard1 \
public-key="xxxxxxxxxxxxxxxxxxxxxxxx"
add address=10.0.0.1/24 comment=defconf interface=bridge.LAN network=10.0.0.0
add address=XXXXXXXXX interface=ether1 network=XXXXXXXXX
add address=172.16.10.1/24 interface=wireguard1 network=172.16.10.0
add address=10.0.0.0/24 gateway=10.0.0.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip firewall address-list
add address=voips.modulus.gr list="Modulus SIP"
add action=add-src-to-address-list address-list="port scanners" \
address-list-timeout=2w chain=input comment="Port Scanners to list" \
protocol=tcp psd=21,3s,3,1
address-list-timeout=2w chain=input comment="NMAP FIN stealth scan" \
protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment="FIN/PSH/URG scan" protocol=\
tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
address-list-timeout=2w chain=input comment="ALL/ALL scan" protocol=tcp \
tcp-flags=fin,syn,rst,psh,ack,urg
address-list-timeout=2w chain=input comment="NMAP NULL scan" protocol=tcp \
tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment="SYN/FIN scan" protocol=tcp \
tcp-flags=fin,syn
address-list-timeout=2w chain=input comment="SYN/RST scan" protocol=tcp \
tcp-flags=syn,rst
add action=accept chain=input comment="WG VPN Rule" dst-port=51820 protocol=\
udp
add action=accept chain=input comment="VPN Allow Rules" dst-port=1701 \
protocol=udp
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=input dst-port=500 protocol=udp
established,related,untracked
invalid
add action=drop chain=input src-address-list="port scanners"
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting comment=DNS connection-state=new \
new-connection-mark=DNS passthrough=yes port=53 protocol=udp
add action=mark-packet chain=prerouting connection-mark=DNS new-packet-mark=\
DNS passthrough=no
add action=mark-connection chain=postrouting connection-state=new \
add action=mark-packet chain=postrouting connection-mark=DNS new-packet-mark=\
DNS passthrough=no
add action=mark-connection chain=prerouting comment="VOIP GW" \
new-connection-mark=VOIP passthrough=yes src-address-list="Modulus SIP"
add action=mark-connection chain=prerouting comment=VOIP new-connection-mark=\
VOIP passthrough=yes port=\
6050,5090,5060-5062,50000-50019,50020-50039,50040-50059,9000-10999 \
protocol=udp
add action=mark-packet chain=prerouting connection-mark=VOIP new-packet-mark=\
VOIP passthrough=no
add action=mark-connection chain=prerouting comment=QUIC connection-state=new \
new-connection-mark=QUIC passthrough=yes port=80,443 protocol=udp
add action=mark-packet chain=prerouting connection-mark=QUIC new-packet-mark=\
QUIC passthrough=no
add action=mark-connection chain=prerouting comment=UDP connection-state=new \
new-connection-mark=UDP passthrough=yes protocol=udp
add action=mark-packet chain=prerouting connection-mark=UDP new-packet-mark=\
UDP passthrough=no
add action=mark-connection chain=prerouting comment=ICMP connection-state=new \
new-connection-mark=ICMP passthrough=yes protocol=icmp
add action=mark-packet chain=prerouting connection-mark=ICMP new-packet-mark=\
ICMP passthrough=no
add action=mark-packet chain=postrouting connection-mark=ICMP \
new-packet-mark=ICMP passthrough=no
add action=mark-packet chain=postrouting comment=ACK new-packet-mark=ACK \
packet-size=0-123 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=prerouting new-packet-mark=ACK packet-size=0-123 \
add action=mark-connection chain=prerouting comment=HTTP connection-mark=\
no-mark connection-state=new new-connection-mark=HTTP passthrough=yes \
port=80,443 protocol=tcp
add action=mark-connection chain=prerouting connection-bytes=5000000-0 \
connection-mark=HTTP connection-rate=2M-200M new-connection-mark=HTTP_BIG \
passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting connection-mark=HTTP_BIG \
new-packet-mark=HTTP_BIG passthrough=no
add action=mark-packet chain=prerouting connection-mark=HTTP new-packet-mark=\
HTTP passthrough=no
add action=mark-connection chain=prerouting comment=OTHER connection-state=\
new new-connection-mark=POP3 passthrough=yes port=995,465,587 protocol=\
tcp
add action=mark-packet chain=prerouting connection-mark=POP3 new-packet-mark=\
OTHER passthrough=no
add action=mark-connection chain=prerouting connection-mark=no-mark \
new-connection-mark=OTHER passthrough=yes
add action=mark-packet chain=prerouting connection-mark=OTHER \
new-packet-mark=OTHER passthrough=no
/ip firewall raw
add action=drop chain=prerouting dst-port=53 in-interface-list=WAN log=yes \
log-prefix="WAN DNS" protocol=udp
/ip firewall service-port
set sip disabled=yes
add disabled=no dst-address=0.0.0.0/0 gateway=XXXXXXXXX routing-table=\
main suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
add address=::/128 comment="defconf: unspecified address" disabled=yes list=\
bad_ipv6
add address=::1/128 comment="defconf: lo" disabled=yes list=bad_ipv6
add address=fec0::/10 comment="defconf: site-local" disabled=yes list=\
bad_ipv6
add address=::ffff:0.0.0.0/96 comment="defconf: ipv4-mapped" disabled=yes \
list=bad_ipv6
add address=::/96 comment="defconf: ipv4 compat" disabled=yes list=bad_ipv6
add address=100::/64 comment="defconf: discard only " disabled=yes list=\
bad_ipv6
add address=2001:db8::/32 comment="defconf: documentation" disabled=yes list=\
bad_ipv6
add address=2001:10::/28 comment="defconf: ORCHID" disabled=yes list=bad_ipv6
add address=3ffe::/16 comment="defconf: 6bone" disabled=yes list=bad_ipv6
/ipv6 firewall filter
established,related,untracked disabled=yes
invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMPv6" disabled=yes \
protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
disabled=yes port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." disabled=yes dst-port=\
546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" disabled=yes \
dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" disabled=yes \
protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" disabled=\
yes protocol=ipsec-esp
"defconf: accept all that matches ipsec policy" disabled=yes \
"defconf: drop everything else not coming from LAN" disabled=yes \
connection-state=invalid disabled=yes
"defconf: drop packets with bad src ipv6" disabled=yes src-address-list=\
bad_ipv6
"defconf: drop packets with bad dst ipv6" disabled=yes dst-address-list=\
bad_ipv6
disabled=yes hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" disabled=yes \
protocol=icmpv6
add action=accept chain=forward comment="defconf: accept HIP" disabled=yes \
protocol=139
add action=accept chain=forward comment="defconf: accept IKE" disabled=yes \
add action=accept chain=forward comment="defconf: accept ipsec AH" disabled=\
yes protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" disabled=\
/snmp
set enabled=yes
/tool mac-server
/tool mac-server mac-winbox
and this is my peer connection via wireguard:
[Interface]
PrivateKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ListenPort = 51820
Address = 172.16.10.2/32
DNS = 1.1.1.1
[Peer]
PublicKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
AllowedIPs = 10.0.0.0/24, 172.16.10.1/32, 0.0.0.0/0
Endpoint = xxxxxxxxx:51820
any ideas for the poor performance? The resources on rb5009 is almost 0% on cpu, i checked all cores and nothing goes above 5% when i am connected with wireguard and try to speed test.
