Wireguard low Throughput
Hello everyone. I should create a peer to peer connection between two locations. The connections in question are two ftth 1000/1000. Currently I have performed tests with a CCR1009 and a hap ax2 and I have a maximum Throughput of 400mbps between the two sites. I simulated the same with ipsec having a Throughput of 300mbps. The final configuration I was thinking of doing with two rb5009. I am a little discouraged given the results obtained with the current hardware. The ccr’s CPU reaches 9%, that of the ax2 barely reaches 60%. I don’t understand what creates the bottleneck. I also tried using two local wan connected to a gigabit switch and I get the same result
400Mbps is actually quite good!
It seems that many users have solved it by forcing the CPU to the maximum and disabling its energy saving. What do you think of this solution? I honestly don’t like it that much.
http://forum.mikrotik.com/t/wireguard-tunnel-speed-problem/171593/1
