My network infrastructure is as follows:
3 ISP with fixed public IPs
ISP 1 connected via a PPPOE connection
ISP 2 and 3 connected to the router via the DHCP client of the router (the IP is fixed on the DHCP server of the box)
The ISP 3 box does not allow the configuration in Bridge mode, so the NAT is configured so that all the ports are redirected to the router.
On the router:
4 vlans with each a specific IP addressing.
Bridges are not used.
IP/SEC configuration IKE2 is not used.
In the firewall rules, nat and mangle are configured.
Customers who will have to use the VPN are under macOS, iOS, Windows and Android.
Objective :
Connect to VPN to access the WAN using public IP which allows access to VPS servers.
The problem lies in the configuration of the Wireguard VPN.
Public and private keys are properly configured.
Handshake is not visible in Winbox, but there is sometimes RX and TX traffic.
The customer (Android) indicates that the connection is established, but impossible to have access to the WAN.
Is this a problem in the rules of the Firewall?
A road problem?
It’s been a while since I make lots of manipulations, and I admit that it becomes painful.
Does anyone have the kindness of looking at my configuration to help me, please?
Any advice, any help will be welcome.
Thanks in advance
Why do you lie about the facts??
Quote: “On the router:
4 vlans with each a specific IP addressing. Bridges are not used.
IP/SEC configuration IKE2 is not used.”
Furthermore you completely mix up vlans and bridges when the vlans are assigned to etheport interfaces and not the bridges…
The solution is ONE bridge all vlans including the management LAN. The bridge should no dhcp!
Two recommendations
a. read this thread for how to: http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/303
b. take one port off the bridge and make it an offbridge safe access point to config vlan bridge filtering. /interface ethernet
set [ find default-name=ether5 ] name=OffBridge
add address=192.168.65.1/29 interface=OffBridge5 network=192.168.65.0
add interface=Offbridge5 list=LAN
Now plug in your laptop into ether5, change ipv4 settings to 192.168.65.2 and you should be in!!!
Which WAN will customers use to acccess your wireguard?
your firewall rules need work
for example you have two rules that are redundant.
→ add action=drop chain=input comment=“WANs : protection DNS” dst-port=53
in-interface-list=Liste_WANs protocol=tcp
in-interface-list=Liste_WANs protocol=udp
AND add action=drop chain=input comment=“Drop all not from LANs”
in-interface-list=!Liste_LANs
The first rules (port 53) can be removed as the second rule already does the same thing and more. ALL ports coming in on the WAN LOL.
The order of the firewall rules in both chains need work.
WHY do you have duplicate rules for DSTNAT rules, port forwarding, these two are incorrect and should be removed. add action=dst-nat chain=dstnat comment=ALARME dst-port=33333 protocol=udp
to-addresses=172.16.0.13 to-ports=33333
add action=dst-nat chain=dstnat dst-port=33333 protocol=tcp to-addresses=
Are you ONLY using WAN3 for port forwarding?
State clearly the purpose of each of your mangling sets of rules, me thinks those are also wrong.
Hello Anav,
First thank you for taking the time to answer me.
Each advice is good to take.
I did not lie about the facts: I carried out many configuration tests, and I had previously created bridges.
But as you can see, they are not used!
DHCP management on bridges was too complex to manage in comparison with VLANS.
To bring you additional elements:
To access wireguard, customers will use sfp-sfpplus4_wan_free2
You say that there are redundant rules, but they do not treat the same protocol (TCP and UDP)
Same for the DSTNAT on Port 33333.
Port Forwarding are used for SFP-SFPPLUS3_WAN_Free and SFP-SFPPLUS4_WAN_FREE2
I defined mangle rules to properly separate routes from each VLAN which correspond to a separate ISP.
The joint diagram may be more explicit. Network infrastructure.pdf (126 KB)
The objective is that users connect to VPN to access external servers (VPS) with the public IP of the ISP.
The firewall of these servers allows access only to this public IP.
The Wireguard interface is up, and there is sometimes a little traffic.
The customer indicates that it is connected, but yet there is no internet access and no ping or traceout is possible.
I cannot identify the problem.
Without a diagram I have no clue what your network looks like.
Are these customers remotely connecting to your MT router to use your internet?
Are the customers behind the MT router and connecting to your CHR in the cloud to get internet
Are the customers behind the MT router and connecting to your connection to a third party VPN provider ??
