Hello! Fellow Mikrotikers, Recently I decided to join the Mikrotik community changing over from Ubiquiti. I’m more of a hobbyist than a professional. So far the setup of my HAP Ax3 and been successful except during the setup of Wireguard. I’ve been following the guides I’ve found on the internet.
What I’ve done
- I’ve a static Public IP
- Setup Wireguard
- My mobile is able to connect to wireguard
My Issue is i have no internet once my wireguard is connected to my mobile and it seems like my android mobile is unable to resolve the DNS.
I’ve been cracking my head for over 2 days and losing sleep over this. Please help!
Below is my router config
# 2024-02-17 08:39:20 by RouterOS 7.13.4
# software id = A2BN-0QWI
# model = C53UiG+5HPaxD2HPaxD
# serial number =
add admin-mac= arp=proxy-arp auto-mac=no comment=defconf \
name=Bridge port-cost-mode=short
set [ find default-name=ether1 ] name="ether1[WAN]"
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Singapore .mode=ap .ssid=Hoooob!-R \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp interface=Bridge lease-time=8h name=defconf
add bridge=Bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=Bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=Bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=Bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=Bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=Bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
/ipv6 settings
set disable-ipv6=yes
add comment=defconf interface=Bridge list=LAN
add comment=defconf interface="ether1[WAN]" list=WAN
add interface=wireguard1 list=LAN
/interface ovpn-server server
set auth=sha512 certificate=server-cert cipher=aes256-cbc,aes256-gcm \
default-profile=VPN-Profile require-client-certificate=yes tls-version=\
only-1.2
/interface wireguard peers
add allowed-address=192.168.2.0/24,192.168.1.0/24 comment="to Mobile" \
interface=wireguard1 persistent-keepalive=10s private-key=\
"" public-key=\
add address=192.168.1.1/24 comment=defconf interface=Bridge network=\
192.168.1.0
add address=192.168.2.1/24 interface=wireguard1 network=192.168.2.0
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
192.168.1.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add action=accept chain=input comment="Allow wireguard" dst-port=13231 \
protocol=udp
add action=accept chain=forward comment="Wg to Internet" in-interface=\
wireguard1 out-interface-list=WAN
add action=accept chain=forward comment="Wg to Lan Traffic" in-interface=\
wireguard1 out-interface-list=LAN
add action=accept chain=input comment="allow WireGuard Traffic" src-address=\
192.168.2.0/24
add chain=forward in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward connection-nat-state=dstnat
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
disabled=yes in-interface-list=!LAN log=yes
connection-state=new disabled=yes in-interface-list=WAN
invalid
connection-state=invalid
ipsec-policy=out,none out-interface=wireguard1
add action=dst-nat chain=dstnat comment=OpenVPN-NAS dst-port=4500 \
in-interface-list=WAN protocol=udp to-addresses=192.168.1.4 to-ports=4500
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.1.0/24,192.168.2.0/24
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Asia/Singapore
/system logging
add topics=ovpn,info
add topics=ovpn,debug
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
