I’m trying to connect a hAP with a Wireguard config I made after reading the forum. The interface appears to come up and send handshakes back and forth, but no traffic is routed over the tunnel.
My intention is any wifi or ethernet connection (apart from ether5) will be routed over the tunnel to a VPS. I’ve checked the Wireguard portion of the config works from a phone or computer normally.
Would anyone be able to tell me where I went wrong?
# xxxx-xx-xx xx:xx:xx by RouterOS 7.10.2
# software id = XUUT-49R1
# model = C52iG-5HaxD2HaxD
add admin-mac=48:A9:8A:68:4F:0E auto-mac=no comment=defconf name=bridge protocol-mode=none
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ac .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.dtim-period=255 .mode=ap .ssid=xxxx \
.tx-power=40 disabled=no security.authentication-types=wpa3-psk .encryption="" .wps=disable
/interface wireguard
add disabled=no listen-port=13231 mtu=1420 name=wireguard1
add address-pool=default-dhcp interface=bridge lease-time=8h name=defconf
/port
set 0 name=serial0
/queue type
set 2 kind=fq-codel
/routing table
add disabled=no fib name=wireguard
add bridge=bridge interface=ether1
add bridge=bridge interface=wifi1
set enabled=yes
set discover-interface-list=none
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=xxx.xxx.xxx.xxx endpoint-port=51820 interface=wireguard1 persistent-keepalive=2m public-key=\
"blahblahblahblahblabh="
add address=192.168.88.4/24 interface=bridge network=192.168.88.0
add address=192.168.89.1/30 interface=ether5 network=192.168.89.0
add address=10.8.0.4 interface=wireguard1 network=10.8.0.4
/ip cloud
set update-time=no
add address=10.8.0.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.8.0.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.4 gateway=192.168.88.1
set allow-remote-requests=yes use-doh-server=https://dns.nextdns.io/xxxxxx verify-doh-cert=yes
/ip dns static
add address=45.90.28.0 name=dns.nextdns.io
add address=45.90.30.0 name=dns.nextdns.io
add address=2a07:a8c0:: name=dns.nextdns.io type=AAAA
add address=2a07:a8c1:: name=dns.nextdns.io type=AAAA
add action=masquerade chain=srcnat log=yes out-interface=wireguard1 src-address=192.168.88.0/24
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.88.1 routing-table=main suppress-hw-offload=no
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard1 routing-table=wireguard scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=10.8.0.0/24 gateway=wireguard1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb
set allow-guests=no interfaces=wifi2
/ip smb shares
/routing rule
add action=lookup disabled=no src-address=192.168.88.0/24 table=wireguard
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
add address=3.pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
I would need to see the VPS wireguard settings (minus public WANIP info and keys etc…)
As far as your local device, it would ridonkulous to state users except etherport5.
You only have one subnet!!
Okay what is the case here? Your config and text are in conflict.
A> is this an Access Point/Switch acting as one
OR
B> is this acting in a router mode.
A. if its a switch there is no pool, dhcp etc for the bridge as that is provided by the upstream router.
B. if its a router then where is your WAN.
Once that is straightened out and your VPS settings are revealed will take seconds to fix.
Removed this part → /ip firewall connection tracking
set enabled=yes
Your wireguard address and network are WRONGLY formatted!
Forget DOH dns for now, traffic isnt going out router its going out wireguard tunnel!
No Requirement for sourcenat, there is no WANIP. Also you have access to VPS wg settings just ensure that 192.168.88.0/24 is included!!!
Remember the traffic when leaving VPS for internet will get sourcenatting of VPS anyway.
No requirement for route for wireguard itself as the router creates that automatically with IP address.
.tx-power=40 disabled=no security.authentication-types=wpa3-psk .encryption=“” .wps=disable
/port
set 0 name=serial0
/queue type
set 2 kind=fq-codel
/routing table
set discover-interface-list=MANAGE
/ip interface list
add name=MANAGE
/ip interface list members
add interface=bridge list=MANAGE
add allowed-address=0.0.0.0/0 endpoint-address=xxx.xxx.xxx.xxx endpoint-port=51820 interface=wireguard1 persistent-keepalive=35s public-key=
“blahblahblahblahblabh=”
add address=192.168.89.1/30 interface=ether5 network=192.168.89.0 comment=“off bridge access”
add address=10.8.0.4/24 interface=wireguard1 network=10.8.0.0
add address=192.168.88.??/24 interface=bridge network=192.168.88.0
/ip cloud
set update-time=no
set allow-remote-requests=yes servers=192.168.88.1,1.1.1.1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard1 routing-table=use-wireguard scope=30 suppress-hw-offload=no target-scope=10
/ip service
/ip smb
/ip smb shares
/routing rule
add action=lookup disabled=no src-address=192.168.88.0/24 table=use-wireguard
/system note
/system ntp client
set enabled=yes
set enabled=no
/tool mac-server
set allowed-interface-list=MANAGE
set enabled=no
(1) DO NOT do dhcp client is bridge. Remove this.
Since the AP is on a private subnet, assign a static IP to the AP. aka XY. ( 192.168.88.XY/24 gateway=192.168.88.1 routing-table=main )
(2) Routing rule, REMOVE interface=bridge Should be simply… /routing rule
add action=lookup src-address=192.168.88.0/24
table=wireguard
(3) In conjunction with (1) add another route.
add dst-address=0.0.0.0/0 gateway=192.168.88.1 routing-table=main
(4) zStill Missing /ip neighbor discovery-settings
(5) copy mistake ?? /interface list dd name=MANAGE
Something didnt seem right, assuming this is an access point switch device getting a private IP from a subnet on the upstream router?
If so, no pool, no nothing… So get rid of those settings.
Added ether5 to the MANAGE interface list.
Change DNS settings to non doh… the traffic is going out vps, not local router.
set [ find default-name=wifi1 ] channel.band=5ghz-ac .skip-dfs-channels=disabled .width=20/40mhz-Ce configuration.beacon-interval=293ms .country="New Zealand" \
.dtim-period=255 .manager=local .mode=ap .ssid=xxxx .tx-power=40 disabled=no security.authentication-types=wpa3-psk .encryption="" .wps=disable
add listen-port=13231 mtu=1420 name=wireguard1
add name=MANAGE
/port
set 0 name=serial0
/queue type
set 2 kind=fq-codel
/routing table
/ipv6 settings
set disable-ipv6=yes
add interface=ether5 list=MANAGE
add allowed-address=0.0.0.0/0 endpoint-address=xxx.xxx.xxx.xxx endpoint-port=51820 interface=wireguard1 persistent-keepalive=35s public-key=\
"blahblah="
/ip cloud
set update-time=no
set allow-remote-requests=yes server=192.168.88.1
/ip service
/ip smb
/ip smb shares
/routing rule
/system note
/system ntp client
set enabled=yes
set enabled=no
/tool mac-server
set enabled=no
