Wireguard on hEX as Client but no (or Slow) Upload
Hello everyone, as i have informed on previus topic /viewtopic.php?t=205638 im new on mikrotik as i have used mostly ubiquiti router untill now i managed to make the basic setup but im strugling for real 3 weeks now with this wireguard thing. I got Wireguard Client keys from a Local Database and im connecting to them as Client. I got the setup on Ubiquiti for months running without any issue and also at Cudy Router and Windows Client.
At the Mikrotik i tried several ways of routing and setup but in every try i had the connection and i got internet access BUT problems with the upload thing (mabe is something else and i see it in the upload)
I have read also other topics that has the same issue with the wireguard but i havent underestand how they fixed or if they fixed it at all.
My setup is supposed to be eth1 and eth2 as WAN port and eth2 to be as failover so i was curius if it would be an issue of that but i even tried with just the basic config from mikrotik and just add the Wireguard but still the same issue. im sending 2 of my lots of tries i did and could not manage to stabilise it.
CONFIG 1 SINGLE WAN
2024-04-07 23:09:08 by RouterOS 7.14.2
software id = M8KE-V5ID
model = RB750Gr3
serial number = HD********2AS
add admin-mac=18:FD:74:8C:28:66 auto-mac=no comment=defconf name=bridge
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
/routing table
add disabled=no fib name=via-WG1
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=5.172.1**.95 endpoint-port=
13231 interface=wireguard1 persistent-keepalive=25s public-key=
“ySD/xFuT****************************S4xyT6wE=”
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=192.168.32.50 interface=wireguard1 network=192.168.32.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1 gateway=
192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,192.168.32.1
/ip dns static
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu out-interface=
wireguard1 passthrough=yes protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=masquerade chain=srcnat out-interface=wireguard1
add disabled=no dst-address=0.0.0.0/0 gateway=wireguard1 routing-table=
via-WG1 suppress-hw-offload=no
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
/ipv6 firewall filter
invalid
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute”
dst-port=33434-33534 protocol=udp
“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500
protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
“defconf: drop everything else not coming from LAN” in-interface-list=
!LAN
“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1”
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
!LAN
/routing rule
add action=lookup disabled=no src-address=192.168.88.0/24 table=via-WG1
/system clock
set time-zone-name=Europe/Athens
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
CONFIG 2 DUAL WAN FAILOVER
2024-04-02 23:02:52 by RouterOS 7.14.2
model = RB750Gr3
serial number = HD2*****AS
add name=Bridge-LAN
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
add name=WAN
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.13.100-192.168.13.254
add name=dhcp_pool1 ranges=192.168.14.200-192.168.14.205
add address-pool=dhcp_pool0 interface=Bridge-LAN lease-time=1d name=dhcp1
add address-pool=dhcp_pool1 interface=ether5 lease-time=6d name=dhcp2
/routing table
add bridge=Bridge-LAN interface=ether3
add bridge=Bridge-LAN interface=ether4
add interface=WAN1 list=WAN
add interface=WAN2 list=WAN
“ySD/xFuTQ0+********************S4xyT6wE=”
add address=192.168.13.1/24 interface=Bridge-LAN network=192.168.13.0
add address=192.168.1.99/24 interface=WAN1 network=192.168.1.0
add address=192.168.2.98/24 interface=WAN2 network=192.168.2.0
add address=192.168.14.1/24 interface=ether5 network=192.168.14.0
/ip dhcp-client
add disabled=yes interface=WAN1
add disabled=yes interface=WAN2
add address=192.168.13.0/24 dns-server=192.168.13.1 gateway=192.168.13.1
add address=192.168.14.0/24 gateway=192.168.14.1
/ip firewall mangle
add action=change-mss chain=forward disabled=yes new-mss=clamp-to-pmtu
out-interface=wireguard1 passthrough=yes protocol=tcp tcp-flags=syn
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
192.168.1.1 pref-src=“” routing-table=main scope=30 suppress-hw-offload=
no target-scope=10
add disabled=no distance=5 dst-address=0.0.0.0/0 gateway=192.168.2.1
pref-src=“” routing-table=main scope=30 suppress-hw-offload=no
target-scope=10
/routing rule
add action=lookup-only-in-table disabled=yes src-address=192.168.13.0/24
table=main
add action=lookup disabled=no src-address=192.168.13.0/24 table=via-WG1
/system clock
/system note
Can you provide guidance on troubleshooting and resolving upload-related issues with Wireguard on Mikrotik routers? I have tried multiple configurations but continue to experience problems with the upload speed, despite having a successful connection and internet access.
monopoly go
I opened this post because I also have the same issue. If you want upload your config also and someone that might know will share his knowledge.
