Wireguard Peer Configuration (pub/private key)
I am new to Mikrotik, I am trying to configure wireguard peer configuration. On Debian system I can generate using below command and populate the private key details and public key (which later I will put in Mikrotik peer configuration) and send the configuration file to the user.
$ wg genkey | tee privatekey | wg pubkey > publickey
How to run that command in Mikrotik? I am not able to get into shell to run it.
You dont really need to, In the MT wireguard configuration, the router will generate both a private and public key for you.
You only need to export the public key to client devices for their use in peer settings.
