Hiya!
I am having some issues with the wireguard interface. There are a few posts describing similar issues, but since the most relevant one is not exactly the same (http://forum.mikrotik.com/t/wireguard-peer-interface-irregularly-stop-working/157002/1) I decided to make a new one.
I have a simple wireguard setup on an hac3, running RouterOS v7.6. The WAN interface (ether1) receives the fixed IP address from the ISP.
- Public and fixed IP assigned to the WAN (ether1) interface.
- 1 wireguard interface with address assigned (192.168.89.1/24) on the default port (13231)
- 3 peers 89.2, 89.3, 89.4, all on /24 subnets.
- Allowed addresses are 89.0/24 for all peers.
- On the input chain, I allow UDP for the default port (13231), Also on the input chain I allow anything with source address 192.168.89.0/24. These accept rules are before any drop rules.
- I have also allowed traffic sourced from 89.0/24 to 88.0/24 and viceversa. This is just to make things easier on my end. I could do with a bridge, but alas, here we are.
This setup is allowing peers are able to connect and the tunnel is established. The tunnel, just does not last very long. In particular, I connect my mobile (iphone, current ios) with the official wireguard app. Things work fine, but at some point (have tried both using 4g and remote wifi) it just stops working. The logs are not useful, as they report the handshake being completed and the connection being alive. Just no traffic is flowing.
Keepalive does not change this situation. I have tried for on the “incoming” peer, only the mikrotik peer and both. Nothing changes. I have also tried connecting the peer from a virtual interface within the same router. That is, one on the 192.168.100.0/24 address WIFI to the wireguard interface on the same router.
As I said, the interface technically works, but it just stops working.
I am posting this after trying for about a week to no avail, and I am hesitant to write a script and just disable and enable the interface to get it running. I would appreciate any help on this matter.
Cheers!
# oct/24/2022 22:10:48 by RouterOS 7.6
# software id = DS1W-MS2G
# model = RBD53iG-5HacD2HnD
# serial number = F34E0FBBFD49
add admin-mac=DC:2C:6E:14:DE:91 auto-mac=no comment=defconf name=bridge
add name=bridge_casa
add name=bridge_domotica
/interface wireguard
add listen-port=13231 mtu=1420 name=wg_oveta
/interface vlan
add interface=ether2 name=vlan50_ether4 vlan-id=50
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
add authentication-types=wpa2-psk management-protection=allowed mode=\
dynamic-keys name=perfil_casa supplicant-identity=MikroTik
dynamic-keys name=perfil_domotica supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto mode=ap-bridge \
security-profile=perfil_casa ssid=oficina wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac \
channel-width=20/40/80mhz-XXXX country=paraguay disabled=no distance=\
indoors frequency=auto mode=ap-bridge security-profile=perfil_casa ssid=\
add disabled=no mac-address=DE:2C:6E:14:DE:97 master-interface=wlan2 name=\
wlan_casa_5 security-profile=perfil_casa ssid=CASA2 wds-default-bridge=\
bridge wps-mode=disabled
add disabled=no mac-address=DE:2C:6E:14:DE:96 master-interface=wlan1 name=\
wlan_casa_24 security-profile=perfil_casa ssid=CASA2 wds-default-bridge=\
add disabled=no mac-address=DE:2C:6E:14:DE:95 master-interface=wlan1 name=\
wlan_domotica security-profile=perfil_domotica ssid=domotica \
wds-default-bridge=bridge wps-mode=disabled
/interface vlan
add interface=wlan_domotica name=vlan10_domotica vlan-id=10
add interface=wlan2 name=vlan50_casa_5 vlan-id=50
add interface=wlan1 name=vlan50_casa_24 vlan-id=50
add name=dhcp ranges=192.168.88.100-192.168.88.254
add name=dhcp_pool_domotica ranges=10.0.0.2-10.0.0.254
add name=dhcp_pool_casa ranges=192.168.1.2-192.168.1.254
add comment="Range of ips for backup vpns" name=vpn-pool ranges=\
192.168.89.100-192.168.89.254
add address-pool=dhcp interface=bridge name=defconf
add address-pool=dhcp_pool_domotica interface=bridge_domotica name=\
dhcp_domotica
add address-pool=dhcp_pool_casa interface=bridge_casa name=dhcp_casa
add bridge=bridge_casa comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge ingress-filtering=no interface=ether3
add bridge=bridge_domotica ingress-filtering=no interface=ether4
add bridge=bridge ingress-filtering=no interface=ether5
add bridge=bridge ingress-filtering=no interface=wlan1
add bridge=bridge ingress-filtering=no interface=wlan2
add bridge=bridge_domotica ingress-filtering=no interface=vlan10_domotica
add bridge=bridge_domotica ingress-filtering=no interface=wlan_domotica
add bridge=bridge_casa ingress-filtering=no interface=vlan50_casa_5
add bridge=bridge_casa ingress-filtering=no interface=vlan50_casa_24
add bridge=bridge_casa ingress-filtering=no interface=wlan_casa_24
add bridge=bridge_casa ingress-filtering=no interface=wlan_casa_5
add bridge=bridge_domotica ingress-filtering=no interface=vlan50_ether4
set discover-interface-list=none
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
add interface=wg_oveta list=LAN
/interface ovpn-server server
set auth=sha1,sha256,sha512 certificate=SERVER cipher=\
blowfish128,aes128,aes192,aes256 default-profile=default-encryption \
require-client-certificate=yes
/interface wireguard peers
add allowed-address=192.168.89.0/24 comment=iphone endpoint-address=\
192.168.89.2 interface=wg_oveta public-key=\
"tezEg/4ckt9iVo="
add allowed-address=192.168.89.0/24 comment=anguja endpoint-address=\
192.168.89.3 interface=wg_oveta public-key=\
"Zke6G1S954Roh8="
add allowed-address=192.168.89.0/24 comment=ykua endpoint-address=\
192.168.89.4 interface=wg_oveta public-key=\
"URD54882YkmoUI="
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
add address=181.94.246.38/24 interface=ether1 network=181.94.246.0
add address=10.0.0.1/24 interface=bridge_domotica network=10.0.0.0
add address=192.168.1.1/24 interface=bridge_casa network=192.168.1.0
add address=192.168.89.1/24 interface=wg_oveta network=192.168.89.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=10.0.0.0/24 gateway=10.0.0.1
add address=192.138.1.0/24 gateway=192.138.1.1
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.100.0/24 gateway=192.168.100.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
add address=192.168.88.1 comment=defconf name=oveta.lan
add address=192.168.88.5 name=mrroboto.lan
add address=192.168.88.6 name=mandua.lan
add address=10.0.0.5 name=test.domotica.lan
add action=accept chain=input dst-port=13231 protocol=udp
add action=accept chain=input src-address=192.168.89.0/24
established,related,untracked
invalid log=yes log-prefix=test
in-interface-list=!LAN
connection-state=invalid
add action=drop chain=forward in-interface=bridge_casa out-interface=bridge
add action=drop chain=forward in-interface=bridge out-interface=\
bridge_domotica
add action=drop chain=forward in-interface=bridge_domotica out-interface=\
bridge_casa
add action=drop chain=forward in-interface=bridge out-interface=bridge_casa
bridge
add action=drop chain=forward in-interface=bridge_casa out-interface=\
bridge_domotica
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
"Allow traffic between .89 and .88 nets for Wireguard\
\n" dst-address=192.168.89.0/24 src-address=192.168.88.0/24
add action=accept chain=forward dst-address=192.168.88.0/24 src-address=\
192.168.89.0/24
add action=dst-nat chain=dstnat comment=Dvr dst-address=181.94.246.38 \
dst-port=8000 protocol=tcp to-addresses=10.0.0.5 to-ports=8000
dst-port=554 protocol=tcp to-addresses=10.0.0.5 to-ports=554
add action=masquerade chain=srcnat comment="OpenVPN NAT" out-interface=\
ether1
/ip firewall service-port
set rtsp disabled=no
add disabled=no dst-address=0.0.0.0/0 gateway=181.94.246.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.88.0/24,192.168.89.0/24
set ssh address=192.168.88.1/32
set www-ssl disabled=no
set api disabled=yes
set winbox address=192.168.88.0/24,192.168.89.0/24
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ppp profile
set *FFFFFFFE bridge=*21 dns-server=8.8.8.8,1.1.1.1 interface-list=LAN \
local-address=192.168.89.1 remote-address=vpn-pool
/system clock
set time-zone-name=America/Asuncion
/system identity
set name=oveta
/system leds
set 0 disabled=yes interface=wlan2 leds=led1,led2,led3,led4,led5 type=\
wireless-signal-strength
set 1 leds=poe-led type=poe-out
set 2 interface=wg_oveta leds=led1
set 3 interface=wg_oveta leds=led2 type=interface-receive
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool traffic-monitor
add interface=bridge name=tmon1 threshold=0
