wireguard peer like gateway mikrotik
Hello!
Is there a way to do the following:
I have built wireguard vpn tunnel between two Mikrotiks (server and client).
I want to do the following:
Clients after Mikrotiks server to go online through the peer(Wireguard server lan--------->>>goint to internet with public ip of Mikrotik Peer).
In the other direction it works correctly with the appropriate routing rules (peers lan-------> using WG server internet)
Thanks in advance!
Can you share your config (/export file=anynameyoulike) without any personal information?
MT server
server.rsc (4.58 KB)
MT peer
peer.rsc (2.09 KB)
Any ideas?
