Wireguard Peering to a VPN provider
Hello all,
I am trying to enable my CRS109 to use wireguard to a VPN provider so that all that are connecting wired and wireless to the CRS109 go out on the internet via the wireguard connection.
If the wireguard drop i do not want clients connected to the Mikrotik to be able to access the internet via the ip given by my ISP.
From my VPN provider all i got is this:
[Interface]
PrivateKey =
Address = 10.xx.xx.xx/16
DNS = 10.12.xx.xx
[Peer]
PublicKey = <some_public_key>
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = wireguardserver.www:51822
PersistentKeepalive = 25
I have used this is an inspiration but it renderd my router as inaccesible (i am not a proton user)
https://protonvpn.com/support/wireguard-mikrotik-routers/
I would appreciate the input of some of the experts here
Kind regards,
Arch
Yes read this article, all good info and pay special attention to para 7[/b] – https://forum.mikrotik.com/viewtopic.php?t=182340
Thank you for pointing me to the article. Eventually it helped me achieve my goal.
All traffic originating from the MT gets out by wireguard interface…so happy days. Only i am not able to access MT by browser or winbox, just console.
Tried to add rule chain input on port 80, it show me login box but the does not continue..
Think if someone tells/explains me why i not able to access webinterface of MT than it is know how to continue
I have pasted my config and would really appreciate some help
# dec/19/2022 22:04:00 by RouterOS 7.6
# software id = ZH7L-6CRU
# model = CRS109-8G-1S-2HnD
# serial number =
add admin-mac=4C:5E:0C:9F:6A:0A auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=***** wireless-protocol=802.11
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk supplicant-identity=\
    MikroTik
add address-pool=default-dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/routing table
add fib name=useWG
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp1
add interface=wireguard1 list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0,::/0 endpoint-address=********* \
    endpoint-port=51822 interface=wireguard1 persistent-keepalive=25m \
    public-key="********"
    192.168.88.0
add address=10.11.8.223/16 interface=wireguard1 network=10.11.0.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=accept chain=forward out-interface=wireguard1 src-address=\
    192.168.88.0/24
    connection-state=invalid
add dst-address=0.0.0.0/0 gateway=wireguard1 routing-table=useWG
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/lcd interface pages
set 0 interfaces=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,sfp1
/routing rule
add action=lookup-only-in-table src-address=192.168.88.0/24 table=useWG
/system clock
set time-zone-name=Europe/Amsterdam
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
You should remove the serial number from the previous post.
It mostly works because your peer settings and wireguard settings are good and the routing information is good,
where its short is in firewall rules.
Change this
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
TO:
add action=accept chain=input in-interface=wireguard1
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment=“drop all else”
To be on the safe side, to allow access to your router from the LAN add an additional route rule… in this order…
/routing rule
add action=lookup-only-in-table dst-address=192.168.88.0/24 table=main
Thank you for all help.
I did alot of config retries which was fun, learned a bit
it turns out if i add to the config:
/routing/rule/add src-address=192.168.88.0/24 dst-address=192.168.88.0/24 action=lookup table=main
Of course i am open to suggestion on how to improve, but very happy with this.
For good measure i am posting my config for future reference and for others
# dec/23/2022 01:18:58 by RouterOS 7.6
# serial number =
add admin-mac=  auto-mac=no comment=defconf name=bridge
/interface wireless
    ap-bridge ssid=xxx wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/routing table
add fib name=useWG
add allowed-address=0.0.0.0/0,::/0 endpoint-address=xxx \
    endpoint-port=xxx interface=wireguard1 public-key=\
    "xxx"
    192.168.88.0
/ip dhcp-client
    192.168.88.1
/ip dns static
    invalid
    192.168.88.0/24
add action=masquerade chain=srcnat disabled=yes out-interface=wireguard1
add action=masquerade chain=srcnat disabled=yes out-interface=ether1
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup dst-address=192.168.88.0/24 src-address=192.168.88.0/24 \
    table=main
add action=lookup src-address=192.168.88.0/24 table=useWG
/system clock
/tool mac-server
