Any idea how I can add port for peer endpoint ip address ? Look like only ip address is allowed aka (1.1.1.1 vs 1.1.1.1:51821)
Or I miss something ?
Maybe is not important but is good to have
It’s currently not possible to enter it in Winbox. Until it’s fixed, you can use command line, it’s possible there.
You can specify port via /interface wireguard edit
It will even show you some sort of mask if endpoint is not set yet.
Webfig doesn’t work too. I tried to create a tunnel with WebFig, and it didn’t work (it uses the zero port - 10.10.10.10:0 - and You can’t change it).
At this moment, Wireguard should be used through the CLI.
