WireGuard: Peers - Unofficial WireGuard Documentation
Peers
Defines the VPN settings for a remote peer capable of routing traffic for one or more addresses (itself and/or other peers). Peers can be either a public bounce server that relays traffic to other peers, or a directly accessible client via LAN/internet that is not behind a NAT and only routes traffic for itself.
All clients must be defined as peers on the public bounce server. Simple clients that only route traffic for themselves, only need to define peers for the public relay, and any other nodes directly accessible. Nodes that are behind separate NATs should not be defined as peers outside of the public server config, as no direct route is available between separate NATs. Instead, nodes behind NATs should only define the public relay servers and other public clients as their peers, and should specify AllowedIPs = 192.0.2.1/24 on the public server that accept routes and bounce traffic for the VPN subnet to the remote NAT-ed peers.
In summary, all nodes must be defined on the main bounce server. NOTE: On client servers, only peers that are directly accessible from a node should be defined as peers of that node, any peers that must be relayed by a bounce server should be left out and will be handled by the relay server's catchall route.
In the configuration outlined in the docs below, a single server public-server1 acts as the relay bounce server for a mix of publicly accessible and NAT-ed clients, and peers are configured on each node accordingly:
in public-server1 wg0.conf (bounce server)
[peer] list: public-server2, home-server, laptop, phone
in public-server2 wg0.conf (simple public client)
[peer] list: public-server1
in home-server wg0.conf (simple client behind NAT)
[peer] list: public-server1, public-server2
in laptop wg0.conf (simple client behind NAT)
in phone wg0.conf (simple client behind NAT)
Examples
Peer is a simple public client that only routes traffic for itself
[Peer]
# Name = public-server2.example-vpn.dev
Endpoint = public-server2.example-vpn.dev:51820
PublicKey = <public key for public-server2.example-vpn.dev>
AllowedIPs = 192.0.2.2/32
Peer is a simple client behind a NAT that only routes traffic for itself
[Peer]
# Name = home-server.example-vpn.dev
Endpoint = home-server.example-vpn.dev:51820
PublicKey = <public key for home-server.example-vpn.dev>
AllowedIPs = 192.0.2.3/32
Peer is a public bounce server that can relay traffic to other peers
[Peer]
# Name = public-server1.example-vpn.tld
Endpoint = public-server1.example-vpn.tld:51820
PublicKey = <public key for public-server1.example-vpn.tld>
# routes traffic to itself and entire subnet of peers as bounce server
PersistentKeepalive = 25
