Hi to everybody.
I ve setup a wireguard connection between two mirkotik (RB5009 and cAP ax) devices to an opnsense firewall.
Wireguard IPs
Opnsense 10.200.0.1/24
cAP ax 10.200.0.2/24
RB5009 10.200.0.3/24
The connection from RB5009 to opnsense works as expected - I can ping opnsense from mikrotik and from mikrotik to opnsense
The connection from cAP to opnsense is established, but I dont have any network activies.
Opnsense is allowing any trafic on the wireguard interface.
Wireguard config RB5009
/interface/wireguard/peers> /interface/wireguard/peers/print
Columns: INTERFACE, PUBLIC-KEY, ENDPOINT-ADDRESS, ENDPOINT-PORT, ALLOWED-ADDRESS, PERSISTENT-KEEPALIVE
# INTERFACE PUBLIC-KEY ENDPOINT-ADDRESS ENDPOINT-PORT ALLOWED-ADDRESS PERSISTENT-KEEPALIVE
0 wireguard1 xxxxxxEo0mvBFAMZ1UTUYtxKgRGfrEu5rA3xBdIgKi4= xx.xx.xx.93 55617 192.168.200.0/24 20s
10.200.0.0/24
::/0
[admin@FW-MT]ping 10.200.0.1
SEQ HOST SIZE TTL TIME STATUS
0 10.200.0.1 56 64 10ms301us
1 10.200.0.1 56 64 11ms188us
sent=2 received=2 packet-loss=0% min-rtt=10ms301us avg-rtt=10ms744us max-rtt=11ms188us
[admin@FW-MT] ping 10.200.0.3
0 10.200.0.3 56 64 284us
1 10.200.0.3 56 64 265us
sent=2 received=2 packet-loss=0% min-rtt=265us avg-rtt=274us max-rtt=284us
cAP ax
0 wireguard1 xxxxxxEo0mvBFAMZ1UTUYtxKgRGfrEu5rA3xBdIgKi4= xx.xx.xx.93 55617 10.200.0.0/24 25s
192.168.200.0/24
::/0
[admin@AP-01] > ping 10.200.0.2
0 10.200.0.2 56 64 156us
1 10.200.0.2 56 64 202us
sent=2 received=2 packet-loss=0% min-rtt=156us avg-rtt=179us max-rtt=202us
[admin@AP-01] > ping 10.200.0.1
0 10.200.0.1 timeout
sent=1 received=0 packet-loss=100%
Also opnsense says, that the devices are connected
wg1 XXXXXzzyNHZEcy5Z8OYYzEH5vIj02V6DhBePOmWk1Wg= FW-MT XX.XX.XX.191:13231 2024-12-01 16:15:54 707.46 MB 3.35 GB
wg1 XXXXXXLwsumMHDX//q7LYTAYq0TE8QvD64W0e4Tm30XU= AP-01 XX.XX.XX.191:13235 2024-12-01 16:15:53 2.77 MB 1.27 MB
both mikrotik devices are behinde the same public IP but not in the same network as the opnsense firewall.
On the RB5009 i ve the possibility to switch between router and bridge, router is selected.
cAP does not have these option.
In this case I dont have created any routes because they are “directly” connected
On both mikrotik devices i ve create a rule for incomming icmp traffic on wireguard interface
Can someone point me the right direction
Thanks a lot
