Wireguard Remonte access no lan no intenet
Hello for everyone,
i want start to tell you that is the first time that I use a mikrotik router.
I want connect from my notebook or my cellular with rds service to administrative server.
I have configurate the router, with a simple wireguard tunnel.
For configure the router I has been refer to help guide on internet.
The problem is that I connect with wireguard but do not access to local lan and navigate in internet.
This is the lan scheme:
and this is the code on the router:
# 2024-02-08 19:26:13 by RouterOS 7.12.1
# software id = 2YL2-04P7
# model = RBD53iG-5HacD2HnD
# serial number = <removed>
add admin-mac=78:9A:18:07:39:69 ageing-time=5m arp=enabled arp-timeout=auto \
    auto-mac=no comment=defconf dhcp-snooping=no disabled=no fast-forward=yes \
    forward-delay=15s igmp-snooping=no max-message-age=20s mtu=auto name=\
    bridge priority=0x8000 protocol-mode=rstp transmit-hold-count=6 \
    vlan-filtering=no
set [ find default-name=ether1 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    -baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full" arp=enabled \
    arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no l2mtu=1598 loop-protect=default loop-protect-disable-time=5m \
    loop-protect-send-interval=5s mac-address=78:9A:18:07:39:68 mtu=1500 \
    name=ether1 orig-mac-address=78:9A:18:07:39:68 rx-flow-control=off \
    tx-flow-control=off
set [ find default-name=ether2 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    loop-protect-send-interval=5s mac-address=78:9A:18:07:39:69 mtu=1500 \
    name=ether2 orig-mac-address=78:9A:18:07:39:69 rx-flow-control=off \
    tx-flow-control=off
set [ find default-name=ether3 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    loop-protect-send-interval=5s mac-address=78:9A:18:07:39:6A mtu=1500 \
    name=ether3 orig-mac-address=78:9A:18:07:39:6A rx-flow-control=off \
    tx-flow-control=off
set [ find default-name=ether4 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    loop-protect-send-interval=5s mac-address=78:9A:18:07:39:6B mtu=1500 \
    name=ether4 orig-mac-address=78:9A:18:07:39:6B rx-flow-control=off \
    tx-flow-control=off
set [ find default-name=ether5 ] advertise="10M-baseT-half,10M-baseT-full,100M\
    loop-protect-send-interval=5s mac-address=78:9A:18:07:39:6C mtu=1500 \
    name=ether5 orig-mac-address=78:9A:18:07:39:6C poe-lldp-enabled=no \
    poe-out=auto-on poe-priority=10 power-cycle-interval=none \
    !power-cycle-ping-address power-cycle-ping-enabled=no \
    !power-cycle-ping-timeout rx-flow-control=off tx-flow-control=off
/queue interface
set bridge queue=no-queue
/interface wireguard
add disabled=no listen-port=13568 mtu=1420 name=external1
/queue interface
set external1 queue=no-queue
/interface ethernet switch
set 0 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch1
set 0 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 1 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 2 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 3 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 4 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 5 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set [ find name=all ] comment="contains all interfaces" exclude="" include="" \
    name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include="" \
    name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" \
    include="" name=dynamic
set [ find name=static ] comment="contains static interfaces" exclude="" \
    include="" name=static
add comment=defconf exclude="" include="" name=WAN
add comment=defconf exclude="" include="" name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet authentication=\
    none default-route-distance=2 ip-type=auto name=default use-network-apn=\
    yes use-peer-dns=yes
/interface macsec profile
set [ find default-name=default ] name=default server-priority=10
set [ find default=yes ] authentication-types="" disable-pmkid=no \
    eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m \
    interim-update=0s management-protection=disabled mode=none \
    mschapv2-username="" name=default radius-called-format=mac:ssid \
    radius-eap-accounting=no radius-mac-accounting=no \
    radius-mac-authentication=no radius-mac-caching=disabled \
    radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
    static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
    none static-sta-private-algo=none static-transmit-key=key-0 \
    supplicant-identity=MikroTik tls-certificate=none tls-mode=\
    no-certificates unicast-ciphers=aes-ccm
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=\
    no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=\
    3 area="" arp=enabled arp-timeout=auto band=2ghz-b/g basic-rates-a/g=\
    6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz \
    compression=no country=etsi default-ap-tx-limit=0 default-authentication=\
    yes default-client-tx-limit=0 default-forwarding=yes \
    disable-running-check=no disabled=no disconnect-timeout=3s distance=\
    indoors frame-lifetime=0 frequency=auto frequency-mode=regulatory-domain \
    frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc\
    s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m\
    cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2\
    3" hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 installation=indoor \
    interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 \
    mac-address=78:9A:18:07:39:6D max-station-count=2007 mode=ap-bridge mtu=\
    1500 multicast-buffering=enabled multicast-helper=default name=wlan1 \
    nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink \
    nv2-qos=default nv2-queue-count=2 nv2-security=disabled nv2-sync-secret=\
    "" on-fail-retry-time=100ms preamble-mode=both radio-name=789A1807396D \
    rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=default \
    secondary-frequency="" security-profile=default skip-dfs-channels=\
    disabled ssid=MikroTik-07396D station-bridge-clone-mac=00:00:00:00:00:00 \
    station-roaming=disabled supported-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
    1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0,1 \
    tx-power-mode=default update-stats-interval=disabled vlan-id=1 vlan-mode=\
    no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
    wds-ignore-ssid=no wds-mode=disabled wireless-protocol=802.11 \
    wmm-support=disabled wps-mode=push-button
set [ find default-name=wlan2 ] adaptive-noise-immunity=none allow-sharedkey=\
    6 area="" arp=enabled arp-timeout=auto band=5ghz-a basic-rates-a/g=6Mbps \
    bridge-mode=enabled channel-width=20mhz compression=no country=etsi \
    default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=\
    0 default-forwarding=yes disable-running-check=no disabled=no \
    disconnect-timeout=3s distance=indoors frame-lifetime=0 frequency=auto \
    frequency-mode=regulatory-domain frequency-offset=0 guard-interval=any \
    hide-ssid=no ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 \
    ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mc\
    s-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,\
    mcs-20,mcs-21,mcs-22,mcs-23" hw-fragmentation-threshold=disabled \
    hw-protection-mode=none hw-protection-threshold=0 hw-retries=7 \
    installation=indoor interworking-profile=disabled keepalive-frames=\
    enabled l2mtu=1600 mac-address=78:9A:18:07:39:6E max-station-count=2007 \
    mode=ap-bridge mtu=1500 multicast-buffering=enabled multicast-helper=\
    default name=wlan2 nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=\
    dynamic-downlink nv2-qos=default nv2-queue-count=2 nv2-security=disabled \
    nv2-sync-secret="" on-fail-retry-time=100ms preamble-mode=both \
    radio-name=789A1807396E rate-selection=advanced rate-set=default \
    rx-chains=0,1 scan-list=default secondary-frequency="" security-profile=\
    default skip-dfs-channels=disabled ssid=MikroTik-07396E \
    station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=disabled \
    supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    tdma-period-size=2 tx-chains=0,1 tx-power-mode=default \
    update-stats-interval=disabled vht-basic-mcs=mcs0-7 vht-supported-mcs=\
    mcs0-9,mcs0-9,mcs0-9 vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150 \
    wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=\
    disabled wireless-protocol=802.11 wmm-support=disabled wps-mode=\
    push-button
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
    hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=\
    0.0.0.0:0 install-hotspot-queue=no login-by=cookie,http-chap name=default \
    smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none \
    !insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=\
    default !parent-queue !queue-type shared-users=1 status-autorefresh=1m \
    transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no use-responder-dns=\
    exclusively
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048,modp1024 dpd-interval=2m \
    dpd-maximum-failures=5 enc-algorithm=aes-128,3des hash-algorithm=sha1 \
    lifetime=1d name=default nat-traversal=yes proposal-check=obey
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=\
    aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=\
    modp1024
add address-pool=default-dhcp authoritative=yes disabled=no interface=bridge \
    lease-script="" lease-time=10m name=defconf use-radius=no
/ppp profile
set *0 address-list="" !bridge !bridge-horizon bridge-learning=default \
    !bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server \
    !idle-timeout !incoming-filter !insert-queue-before !interface-list \
    !local-address name=default on-down="" on-up="" only-one=default \
    !outgoing-filter !parent-queue !queue-type !rate-limit !remote-address \
    !session-timeout use-compression=default use-encryption=default use-ipv6=\
    yes use-mpls=default use-upnp=default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon bridge-learning=default \
    !local-address name=default-encryption on-down="" on-up="" only-one=\
    default !outgoing-filter !parent-queue !queue-type !rate-limit \
    !remote-address !session-timeout use-compression=default use-encryption=\
    yes use-ipv6=yes use-mpls=default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
    red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 \
    pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 \
    pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 \
    pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 \
    pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address \
    pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
    pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 \
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set wlan1 queue=wireless-default
set wlan2 queue=wireless-default
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
    3200 framer-policy=none
set wlan2 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M\
    bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:\
    17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H\
    T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-\
    7:17"
set wlan2 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M\
    7:17"
/routing bgp template
set default as=65530 name=default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-protocol=MD5 disabled=\
    no encryption-protocol=DES name=public read-access=yes security=none \
    write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=1000 \
    disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=\
    0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=\
    bsd-syslog target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
    eb,sniff,sensitive,api,romon,rest-api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
    ssword,web,sniff,sensitive,api,romon,rest-api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
    winbox,password,web,sniff,sensitive,api,romon,rest-api" skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled \
    mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path="" \
    require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=no crl-store=ram crl-use=no
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=\
    defconf disabled=no edge=auto fast-leave=no frame-types=admit-all \
    horizon=none hw=yes ingress-filtering=yes interface=ether2 \
    internal-path-cost=10 learn=auto multicast-router=temporary-query \
    path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no \
    restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes \
    unknown-unicast-flood=yes
    horizon=none hw=yes ingress-filtering=yes interface=ether3 \
    horizon=none hw=yes ingress-filtering=yes interface=ether4 \
    horizon=none hw=yes ingress-filtering=yes interface=ether5 \
    horizon=none ingress-filtering=yes interface=wlan1 internal-path-cost=10 \
    learn=auto multicast-router=temporary-query path-cost=10 point-to-point=\
    auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no \
    horizon=none ingress-filtering=yes interface=wlan2 internal-path-cost=10 \
/interface bridge port-controller
# disabled
set bridge=none cascade-ports="" switch=none
/interface bridge port-extender
# disabled
set control-ports="" excluded-ports="" switch=none
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no \
    use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes \
    tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=\
    1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m \
    udp-stream-timeout=3m udp-timeout=10s
set discover-interface-list=LAN lldp-med-net-policy-vlan=disabled mode=\
    tx-and-rx protocol=cdp,lldp,mndp
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes \
    arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes \
    max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=\
    yes send-redirects=yes tcp-syncookies=no
/ipv6 settings
set accept-redirects=yes-if-forwarding-disabled accept-router-advertisements=\
    yes-if-forwarding-disabled disable-ipv6=no forward=yes \
    max-neighbor-entries=4096
/interface detect-internet
set detect-interface-list=none internet-interface-list=none \
    lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set accept-proto-version=all accept-pseudowire-type=all allow-fast-path=no \
    authentication=pap,chap,mschap1,mschap2 caller-id-type=ip-address \
    default-profile=default-encryption enabled=no keepalive-timeout=30 \
    l2tpv3-circuit-id="" l2tpv3-cookie-length=0 l2tpv3-digest-hash=md5 \
    !l2tpv3-ether-interface-list max-mru=1450 max-mtu=1450 max-sessions=\
    unlimited mrru=disabled one-session-per-host=no use-ipsec=no
add comment=defconf disabled=no interface=bridge list=LAN
add comment=defconf disabled=no interface=ether1 list=WAN
add disabled=no interface=external1 list=LAN
/interface lte settings
set firmware-path=firmware mode=auto
/interface ovpn-server server
set auth=sha1,md5,sha256,sha512 certificate=*0 cipher=blowfish128,aes128-cbc \
    default-profile=default enable-tun-ipv6=no enabled=no ipv6-prefix-len=64 \
    keepalive-timeout=60 mac-address=FE:C4:41:C9:53:CC max-mtu=1500 mode=ip \
    netmask=24 port=1194 protocol=tcp redirect-gateway=disabled reneg-sec=\
    3600 require-client-certificate=no tls-version=any tun-server-ipv6=::
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
    default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
    disabled pfs=no port=443 tls-version=any verify-client-certificate=no
/interface wireguard peers
add allowed-address=10.10.0.2/30 client-endpoint="" comment=\
    "connessioni esterne per PC" disabled=no endpoint-address=0.0.0.0 \
    endpoint-port=13568 interface=external1 persistent-keepalive=10s \
    preshared-key="" private-key="" public-key=\
    "KEY"
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
    00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
    frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" \
    caps-man-names="" certificate=none discovery-interfaces="" enabled=no \
    interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
    multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
    no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
add address=192.168.88.1/24 comment=defconf disabled=no interface=bridge \
    network=192.168.88.0
add address=10.10.0.2/32 disabled=no interface=external1 network=10.10.0.2
add address=192.168.50.28/24 disabled=no interface=ether1 network=\
    192.168.50.0
/ip cloud
set back-to-home-vpn=revoked-and-disabled ddns-enabled=no \
    ddns-update-interval=none update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-client
add add-default-route=yes comment=defconf default-route-distance=1 \
    dhcp-options=hostname,clientid disabled=yes interface=ether1 \
    use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set accounting=yes interim-update=0s radius-password=empty store-leases-disk=\
    5m
add address=192.168.88.0/24 caps-manager="" comment=defconf dhcp-option="" \
    dns-server=192.168.88.1,8.8.8.8,8.8.4.4 gateway=192.168.88.1 !next-server \
    ntp-server="" wins-server=""
set address-list-extra-time=0s allow-remote-requests=yes cache-max-ttl=1w \
    cache-size=2048KiB doh-max-concurrent-queries=50 \
    doh-max-server-connections=5 doh-timeout=5s max-concurrent-queries=100 \
    max-concurrent-tcp-sessions=20 max-udp-packet-size=4096 \
    query-server-timeout=2s query-total-timeout=10s servers=8.8.8.8,8.8.4.4 \
    use-doh-server="" verify-doh-cert=no
/ip dns static
add address=192.168.88.1 comment=defconf disabled=no name=router.lan ttl=1d
add action=accept chain=input comment="open porta external1" \
    !connection-bytes !connection-limit !connection-mark \
    !connection-nat-state !connection-rate !connection-state !connection-type \
    !content disabled=no !dscp !dst-address !dst-address-list \
    !dst-address-type !dst-limit dst-port=13568 !fragment !in-bridge-port \
    !in-bridge-port-list !in-interface !in-interface-list !ingress-priority \
    !ipsec-policy !ipv4-options !layer7-protocol !limit log=no log-prefix="" \
    !nth !out-bridge-port !out-bridge-port-list !out-interface \
    !out-interface-list !packet-mark !packet-size !per-connection-classifier \
    !port !priority protocol=udp !psd !random !routing-mark !src-address \
    !src-address-list !src-address-type !src-mac-address !src-port !time \
    !tls-host !ttl
add action=accept chain=input !connection-bytes !connection-limit \
    !connection-mark !connection-nat-state !connection-rate !connection-state \
    !connection-type !content disabled=no !dscp !dst-address \
    !dst-address-list !dst-address-type !dst-limit !fragment !in-bridge-port \
    !priority !protocol !psd !random !routing-mark src-address=10.10.0.0/30 \
    !src-address-list !src-address-type !src-mac-address !time !tls-host !ttl
add action=accept chain=forward !connection-bytes !connection-limit \
    !connection-type !content disabled=no !dscp dst-address=192.168.88.0/24 \
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    ipsec-policy=out,none out-interface-list=WAN !to-addresses !to-ports
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=yes ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set rtsp disabled=yes ports=554
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" \
    disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=\
    all src-address=::/0 template=yes
/ip ipsec settings
set accounting=yes interim-update=0s xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster \
    cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no \
    max-cache-object-size=2048KiB max-cache-size=unlimited \
    max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
    parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no \
    src-address=::
/ip service
set telnet address="" disabled=no port=23 vrf=main
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80 vrf=main
set ssh address="" disabled=no port=22 vrf=main
set www-ssl address="" certificate=none disabled=yes port=443 tls-version=any \
    vrf=main
set api address="" disabled=no port=8728 vrf=main
set winbox address="" disabled=no port=8291 vrf=main
set api-ssl address="" certificate=none disabled=no port=8729 tls-version=any \
    vrf=main
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
    all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
    max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set auth-method=none connection-idle-timeout=2m enabled=no max-connections=\
    200 port=1080 version=4 vrf=main
/ip ssh
set allow-none-crypto=no always-allow-password-login=no forwarding-enabled=no \
    host-key-size=2048 host-key-type=rsa strong-crypto=no
/ip tftp settings
set max-block-size=4096
/ip traffic-flow
set active-flow-timeout=30m cache-entries=64k enabled=no \
    inactive-flow-timeout=15s interfaces=all packet-sampling=no \
    sampling-interval=0 sampling-space=0
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes \
    dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes \
    igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes \
    ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=\
    yes nat-dst-port=yes nat-events=no nat-src-address=yes nat-src-port=yes \
    out-interface=yes packets=yes protocol=yes src-address=yes \
    src-address-mask=yes src-mac-address=yes src-port=yes sys-init-time=yes \
    tcp-ack-num=yes tcp-flags=yes tcp-seq-num=yes tcp-window-size=yes tos=yes \
    ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/ipv6 firewall address-list
add address=::/128 comment="defconf: unspecified address" disabled=no \
    dynamic=no list=bad_ipv6
add address=::1/128 comment="defconf: lo" disabled=no dynamic=no list=\
    bad_ipv6
add address=fec0::/10 comment="defconf: site-local" disabled=no dynamic=no \
    list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment="defconf: ipv4-mapped" disabled=no \
add address=::/96 comment="defconf: ipv4 compat" disabled=no dynamic=no list=\
    bad_ipv6
add address=100::/64 comment="defconf: discard only " disabled=no dynamic=no \
    list=bad_ipv6
add address=2001:db8::/32 comment="defconf: documentation" disabled=no \
add address=2001:10::/28 comment="defconf: ORCHID" disabled=no dynamic=no \
    list=bad_ipv6
add address=3ffe::/16 comment="defconf: 6bone" disabled=no dynamic=no list=\
    bad_ipv6
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=yes advertise-mac-address=yes \
    disabled=no dns="" hop-limit=unspecified interface=all \
    managed-address-configuration=no mtu=unspecified other-configuration=no \
    pref64="" ra-delay=3s ra-interval=3m20s-10m ra-lifetime=30m \
    ra-preference=medium reachable-time=unspecified retransmit-interval=\
    unspecified
/ipv6 nd prefix default
set autonomous=yes preferred-lifetime=1w valid-lifetime=4w2d
/mpls settings
set allow-fast-path=yes dynamic-label-range=16-1048575 propagate-ttl=yes
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no \
    use-radius=no
/radius incoming
set accept=no port=3799 vrf=main
/routing igmp-proxy
set query-interval=2m5s query-response-interval=10s quick-leave=no
/routing settings
set single-process=no
/snmp
set contact="" enabled=no engine-id-suffix="" location="" src-address=:: \
    trap-community=public trap-generators=temp-exception trap-target="" \
    trap-version=1 vrf=main
/system clock
set time-zone-autodetect=yes time-zone-name=Europe/Rome
/system clock manual
set dst-delta=+00:00 dst-end="1970-01-01 00:00:00" dst-start=\
    "1970-01-01 00:00:00" time-zone=+00:00
/system identity
set name=MikroTik
/system leds
set 0 disabled=no leds=poe-led type=poe-out
set 1 disabled=no interface=ether1 leds=led1 type=interface-activity
set 2 disabled=no interface=ether2 leds=led2 type=interface-activity
set 3 disabled=no interface=ether3 leds=led3 type=interface-activity
set 4 disabled=no interface=ether4 leds=led4 type=interface-activity
set 5 disabled=no interface=ether5 leds=led5 type=interface-activity
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=no
/system ntp client
set enabled=no mode=unicast servers="" vrf=main
/system ntp server
set auth-key=none broadcast=no broadcast-addresses="" enabled=no \
    local-clock-stratum=5 manycast=no multicast=no use-local-clock=no vrf=\
    main
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
set 7 cpu=auto
set 8 cpu=auto
/system resource irq rps
set ether1 disabled=yes
set ether2 disabled=yes
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
/system resource usb settings
set authorization=no
/system routerboard settings
set auto-upgrade=no boot-device=nand-if-fail-then-ethernet boot-protocol=\
    bootp force-backup-booter=no protected-routerboot=disabled \
    reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system routerboard mode-button
set enabled=no hold-time=0s..1m on-event=""
/system routerboard reset-button
/system routerboard wps-button
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes ping-start-after-boot=5m \
    ping-timeout=1m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
    100
/tool e-mail
set from=<> port=25 server=0.0.0.0 tls=no user="" vrf=main
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
/tool sms
set allowed-number="" auto-erase=no channel=0 port=none receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any \
    filter-dst-ip-address="" filter-dst-ipv6-address="" \
    filter-dst-mac-address="" filter-dst-port="" filter-interface="" \
    filter-ip-address="" filter-ip-protocol="" filter-ipv6-address="" \
    filter-mac-address="" filter-mac-protocol="" \
    filter-operator-between-entries=or filter-port="" filter-size="" \
    filter-src-ip-address="" filter-src-ipv6-address="" \
    filter-src-mac-address="" filter-src-port="" filter-stream=no \
    filter-vlan="" memory-limit=100KiB memory-scroll=yes only-headers=no \
    streaming-enabled=no streaming-server=0.0.0.0:37008
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=no \
    stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
    use-radius=no
/user settings
set minimum-categories=0 minimum-password-length=0
Thank you for all for the help!
Good first post !
Can you also share the settings on the notebook where the wireguard client is running ? (remove WAN IP where you connect to and Private/Public keys, just note they are there).
Much easier if you dont use verbose mode for config pastes…
The router is acting as server for handshake dont need the stuff in orange. The client should have /32 …
add allowed-address=10.10.0.2/32 client-endpoint=“” comment=
“connessioni esterne per PC” disabled=no endpoint-address=0.0.0.0
preshared-key=“” private-key=“” public-key=\
YOUR IP address is wroing for wireguard..
add address=10.10.0**.2/32** disabled=no interface=external1 network=10.10.0**.2**
SHOULD BE
add address=10.10.0.1/24 disabled=no interface=external1 network=10.10.0.0
Thank you!
This is the code:
[Interface]
Address = 10.10.0.2/30
DNS = 8.8.8.8
ListenPort = 13568
PrivateKey = KEY
[Peer]
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = XXX.XXX.XXX.XXX:13568
PublicKey = key
Thank you very much tomorrow I try the code that you suggest!
Why 10.10.0.2/30 as address ?
Having the 30 should not hurt the connection, ( i prefer a standard /24 ) but he should ensure he has a keep alive set on the notebook!!
I have changed the setting to:
add address=192.168.200.1/24 disabled=no interface=external1 network=192.168.200.0
and chnged Persistent Keepalive from 10 to 5 second on router and notebook/cellular
But the problem is the same
This is my new configuration:
# 2024-02-09 09:39:44 by RouterOS 7.12.1
# serial number =
add admin-mac=78:9A:18:07:39:69 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid=MikroTik-07396D wireless-protocol=802.11
set [ find default-name=wlan2 ] distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid=MikroTik-07396E wireless-protocol=802.11
add listen-port=13568 mtu=1420 name=external1
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=wlan2
add interface=external1 list=LAN
add allowed-address=192.168.200.1/24 comment="connessioni esterne per PC" \
    endpoint-address=0.0.0.0 endpoint-port=13568 interface=external1 \
    persistent-keepalive=5s public-key=\
    "key"
    192.168.88.0
add address=192.168.200.0/24 interface=external1 network=192.168.200.0
add address=192.168.50.28/24 interface=ether1 network=192.168.50.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=\
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add action=accept chain=input comment="open porta external1" dst-port=13568 \
    protocol=udp
add action=accept chain=input disabled=yes src-address=192.168.200.0/24
add action=accept chain=forward disabled=yes dst-address=192.168.88.0/24 \
    invalid
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Rome
/system note
set show-at-login=no
/tool mac-server
for the router and this for notebook:
[Interface]
Address = 192.168.200.1/24
DNS = 8.8.8.8
ListenPort = 13568
PrivateKey = KEY
[Peer]
PublicKey = key
Messed again
should be
add address=192.168.200.1/24 interface=external1 network=192.168.200.0
    "key"
should be
add allowed-address=192.168.200.2/32 comment="connessioni esterne per PC" \
    "key"
[Interface]
DNS = 8.8.8.8
ListenPort = 13568
PrivateKey = KEY
should be
[Interface]
Address = 192.168.200.2/24
DNS = 8.8.8.8
ListenPort = 13568
PrivateKey = KEY
Yup, it actually got worse not better LOL…
Router allowed IPs
  • the allowed IP is to identify the remote user(s), thus it should be 192.168.200**.2**/32
  • I stated to remove keep alive on router, it is not needed on the server for wg handshake
  • remove the endpoint address entry of 0.0.0.0/0 and endpoint port, not required.
Router IP address
  • the address is in the wrong format should be
    add address=192.168.200**.1**/24 interface-external1 network=192.168.200.0
NOTEBOOK address
  • should be 192.168.200.2/24
  • still missing keep alive 35s is fine.
Hello, everybody!
Problem solved, on notebook I changed DNS 8.8.8.8 with 1.1.1.1 (do not ask me why do not function 8.8.8.8 ) and on cellular I use the Vodafone DNS (sim card is Vodafone), without changing any other parameters… Correcting the other errors you reported to me!
You are a very helpfull community
Thak you for all!
Awesome, glad it worked out for you.
Next time try putting in the Wireguard IP of the MT for DNS on your notebook wireguard settings!
192.168.200.1/32 and see if that also works.
I tried to set 192.168.200.1/32 and it works on both the notebook and the mobile phone!
Why this question?
Just the way I recommend doing DNS, wanted to make sure it worked in your scenario.
