Wireguard roadwarrior on LTE router- Handshake failed
Hi i like to establish on Wireguard peer to access the router from remote for management. I take the simple example from the official guide:
https://help.mikrotik.com/docs/spaces/ROS/pages/69664792/WireGuard
But i do not get a successfull handshake on client. Client is currently a phone and has ip4 & ip6.
I cant see any packages for wireguard in the log. So i guess its pretty basic.
Without seeing your config, hard to see what you have done??
Assuming you have a public WANIP or you can forward ports from an ISP router that has a public IP??
If it’s an ARM device, you might able to the BackToHome to setup WireGuard:
https://help.mikrotik.com/docs/spaces/ROS/pages/197984280/Back+To+Home
If that worked, you’d know everything else is working. So if you did want to use “real” WG, you know it worked first. And BackToHome being enabled would give you some “example” config.
Hi I was able to use BTH. I had attached my config to the first post. I don’t know why it is missing.
But thanks.
