Hello everyone,
I’ve been trying to get WireGuard S2S working for many days, but it’s not working as I’d like.
I’m using 3 MikroTik devices in a test environment: R1 (Wireguard Server), R2 (Wireguard Client), and R3 (Router).
The 3 MikroTik devices are connected as follows:
R1 ether1 → R3 ether1
R1 ether2 → R3 ether2
R2 ether1 → R3 ether3
R2 ether2 → R3 ether4
On router R1, I created 2 WireGuard servers, and I want server 1 to operate only on ether1 and server 2 only on ether2. Similarly, on router R2, I created 2 WireGuard clients. I want client 1 to go out through ether1 of R2 and connect to ether1 of R1’s server, and client 2 to go out through ether2 of R2 and connect to ether2 of R1’s server.
Unfortunately, it’s not working very well. Sometimes only one tunnel works, and other times both work but they both use the same ether interface. I believe I made a mistake marking the traffic in the mangle rules, as WireGuard is not behaving exactly as I want.
These are the configurations of the three routers:
#R1
add name=bridge1
add name=bridge2
set [ find default-name=ether1 ] comment="WAN 1"
set [ find default-name=ether2 ] comment="WAN 2"
/interface wireguard
add listen-port=13231 mtu=1420 name=WG1 private-key=""
add listen-port=13232 mtu=1420 name=WG2 private-key=""
/routing table
add disabled=no fib name=ISP1_table
add disabled=no fib name=ISP2_table
add bridge=bridge2 interface=ether4
/ip settings
set rp-filter=strict tcp-syncookies=yes
/interface wireguard peers
add allowed-address=0.0.0.0/0 interface=WG1 name=peer1 persistent-keepalive=25s preshared-key="" private-key="" public-key=\
"" responder=yes
add allowed-address=0.0.0.0/0 interface=WG2 name=peer2 persistent-keepalive=25s preshared-key="" private-key="" public-key=\
"" responder=yes
add address=10.1.0.2/30 interface=ether1 network=10.1.0.0
add address=10.1.1.2/30 interface=ether2 network=10.1.1.0
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
add address=192.168.10.1/24 interface=bridge2 network=192.168.10.0
add address=10.100.100.1/24 interface=WG1 network=10.100.100.0
add address=10.200.200.1/24 interface=WG2 network=10.200.200.0
/ip firewall mangle
add action=mark-connection chain=output connection-mark=no-mark dst-port=13233 new-connection-mark=ISP1 protocol=udp
add action=mark-connection chain=output connection-mark=no-mark dst-port=13234 new-connection-mark=ISP2 protocol=udp
add action=mark-connection chain=prerouting connection-state=new in-interface=ether1 new-connection-mark=ISP1
add action=mark-connection chain=prerouting connection-state=new in-interface=ether2 new-connection-mark=ISP2
add action=mark-routing chain=output connection-mark=ISP1 new-routing-mark=ISP1_table
add action=mark-routing chain=output connection-mark=ISP2 new-routing-mark=ISP2_table
add action=masquerade chain=srcnat out-interface=ether2
add comment=WAN1 disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.1.0.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add comment=WAN2 disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.1.1.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=WAN1 disabled=no distance=5 dst-address=0.0.0.0/0 gateway=10.1.0.1 routing-table=ISP1_table scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=WAN2 disabled=no distance=5 dst-address=0.0.0.0/0 gateway=10.1.1.1 routing-table=ISP2_table scope=30 suppress-hw-offload=no target-scope=10
/system identity
set name=R1
#R2
add name=bridge1
add listen-port=13233 mtu=1420 name=WG1 private-key=""
add listen-port=13234 mtu=1420 name=WG2 private-key=""
/routing table
/ip settings
add allowed-address=0.0.0.0/0 endpoint-address=10.1.0.2 endpoint-port=13231 interface=WG1 name=peer1 persistent-keepalive=25s preshared-key="" public-key=""
add allowed-address=0.0.0.0/0 endpoint-address=10.1.1.2 endpoint-port=13232 interface=WG2 name=peer2 persistent-keepalive=25s preshared-key="" public-key=""
add address=10.2.0.2/30 interface=ether1 network=10.2.0.0
add address=10.2.1.2/30 interface=ether2 network=10.2.1.0
add address=192.168.2.1/24 interface=bridge1 network=192.168.2.0
add address=10.100.100.2/24 interface=WG1 network=10.100.100.0
add address=10.200.200.2/24 interface=WG2 network=10.200.200.0
/ip firewall mangle
add action=mark-connection chain=output dst-port=13231 new-connection-mark=ISP1 protocol=udp
add action=mark-connection chain=output dst-port=13232 new-connection-mark=ISP2 protocol=udp
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.2.0.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.2.1.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no distance=5 dst-address=0.0.0.0/0 gateway=10.2.0.1 routing-table=ISP1_table scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no distance=5 dst-address=0.0.0.0/0 gateway=10.2.1.1 routing-table=ISP2_table scope=30 suppress-hw-offload=no target-scope=10
add disabled=no dst-address=192.168.1.0/24 gateway=10.100.100.1 routing-table=main suppress-hw-offload=no
add disabled=no dst-address=192.168.10.0/24 gateway=10.200.200.1 routing-table=main suppress-hw-offload=no
/system identity
set name=R2
#R3
/ip settings
add address=10.1.0.1/30 interface=ether1 network=10.1.0.0
add address=10.1.1.1/30 interface=ether2 network=10.1.1.0
add address=10.2.0.1/30 interface=ether3 network=10.2.0.0
add address=10.2.1.1/30 interface=ether4 network=10.2.1.0
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/system identity
set name=R3
