Hello, I have a WG server running on a 5009 ROS 7.5 and i have a WG road warrior client.
I am trying to connect from my road warrior client to mikrotik and i get this error: Sending initiation handshake to peer1 did not complete after 5 sec
mikrotik is not behind CGNAT. Also i want to mention that i already have l2tp with IPSEC vpn server on mikrotik and roadwarriors are working perfectly. I want to switch from l2tp VPN to wireguard VPN because it is easier to setup on mobile phones and devices generally.
My mikrotik config is the bellow:
add admin-mac=DC:2C:6E:3B:C7:89 auto-mac=no comment=defconf name=bridge.LAN
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool1 ranges=10.0.0.100-10.0.0.199
add name=vpn_pool ranges=10.10.10.2-10.10.10.11
add address-pool=dhcp_pool1 interface=bridge.LAN lease-time=1w1d name=dhcp1
/ppp profile
add change-tcp-mss=yes local-address=10.10.10.1 name=vpn_profile \
remote-address=vpn_pool use-encryption=yes
add bridge=bridge.LAN comment=defconf interface=ether3
add bridge=bridge.LAN comment=defconf interface=ether4
add bridge=bridge.LAN comment=defconf interface=ether5
add bridge=bridge.LAN comment=defconf interface=ether6
add bridge=bridge.LAN comment=defconf interface=ether7
add bridge=bridge.LAN comment=defconf interface=ether8
add bridge=bridge.LAN comment=defconf interface=sfp-sfpplus1
/ip settings
set tcp-syncookies=yes
/ipv6 settings
set disable-ipv6=yes
/interface l2tp-server server
set authentication=mschap2 default-profile=vpn_profile enabled=yes use-ipsec=\
required
add comment=defconf interface=bridge.LAN list=LAN
add interface=ether2 list=WAN
add interface=wireguard1 list=LAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=172.16.10.3/32,10.0.0.0/24 interface=wireguard1 \
public-key="SNXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX6yTM="
add address=10.0.0.1/24 comment=defconf interface=bridge.LAN network=10.0.0.0
add address=91.XXX.169.238/30 interface=ether1 network=91.XXX.169.236
add address=172.16.10.1/24 comment="WG VPN" interface=wireguard1 network=\
172.16.10.0
add address=10.0.0.0/24 gateway=10.0.0.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add action=add-src-to-address-list address-list="port scanners" \
address-list-timeout=2w chain=input comment="Port Scanners to list" \
protocol=tcp psd=21,3s,3,1
address-list-timeout=2w chain=input comment="NMAP FIN stealth scan" \
protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment="FIN/PSH/URG scan" protocol=\
tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
address-list-timeout=2w chain=input comment="ALL/ALL scan" protocol=tcp \
tcp-flags=fin,syn,rst,psh,ack,urg
address-list-timeout=2w chain=input comment="NMAP NULL scan" protocol=tcp \
tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment="SYN/FIN scan" protocol=tcp \
tcp-flags=fin,syn
address-list-timeout=2w chain=input comment="SYN/RST scan" protocol=tcp \
tcp-flags=syn,rst
add action=jump chain=input comment="SYN Flood INPUT" connection-state=new \
jump-target=syn-attack protocol=tcp tcp-flags=syn
add action=accept chain=input comment="WG VPN Rule" dst-port=13231 protocol=\
udp
add action=accept chain=input comment="VPN Allow Rules" dst-port=1701 \
protocol=udp
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=input dst-port=500 protocol=udp
established,related,untracked
invalid
add action=drop chain=input src-address-list="port scanners"
in-interface-list=!LAN
add action=jump chain=forward comment="SYN Flood FW" connection-state=new \
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=accept chain=syn-attack connection-state=new limit=400,5:packet \
add action=drop chain=syn-attack connection-state=new log=yes log-prefix=\
SYN-ATK protocol=tcp tcp-flags=syn
add action=dst-nat chain=dstnat disabled=yes dst-port=30000-35000 \
in-interface-list=WAN protocol=udp to-addresses=10.0.0.220 to-ports=\
30000-35000
add action=dst-nat chain=dstnat dst-port=5001 in-interface-list=WAN protocol=\
tcp to-addresses=10.0.0.220 to-ports=5001
add action=dst-nat chain=dstnat dst-port=5090 in-interface-list=WAN protocol=\
tcp to-addresses=10.0.0.220 to-ports=5090
udp to-addresses=10.0.0.220 to-ports=5090
/ip firewall raw
add action=drop chain=prerouting dst-port=53 in-interface-list=WAN log=yes \
log-prefix="WAN DNS" protocol=udp
/ip firewall service-port
set sip disabled=yes
add disabled=no dst-address=0.0.0.0/0 gateway=91.XXX.169.237 routing-table=\
main suppress-hw-offload=no
My Client setup is above:
[Interface]
PrivateKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
ListenPort = 13231
Address = 172.16.10.3/32
[Peer]
PublicKey = TgXXXXXXXXXXXXXXXXXXXXXXXXXXXXXmE=
AllowedIPs = 172.16.10.1/32, 10.0.0.0/24
Endpoint = 91.XXX.169.238:13231
WG interface and peer from mikrotik side and client side seems to have some packet traffic but access is not reachable.
Also from mikrotik peer side, the handshake of my client is 00:00:00.
Any ideas what is wrong?
