Hi all! Apologies in advance, seems like lots of questions around Wireguard setup. I’ve watched some videos, and read other articles, but still missing something. I’m working to get iOS devices to use Wireguard.
If I follow correctly, it goes like this:
iOS Device → Wireguard →
- Generate Public/Private Keys
- Configure a static IP/mask for Address
- Add peer info including Public Key (from Wireguard interface)
- Endpoint is external IP and port
- allowed IPs 0.0.0.0/0 for all traffic testing
Then in RouterOS I setup wireguard interface:
- listen port is default 13231
This is where I get confused a little bit.
So when you configure a Peer, if you do it through the web interface, it asks for things like:
- name
- interface - my wireguard interface
- Public Key - This seems to want to generate a key for the Peer
- Private Key
- Endpoint - is this the IP/domain of the wireguard service?
- Port - Wireguard external configured port on service?
- Allowed address - 0.0.0.0/0
Then down towards the bottom there is more “Client” configuration, with
- Address - Local IP for VPN device
- DNS
- Client Endpoint - What is this compared to the Endpoint above?
I’ve been putting keys here and there trying to get the right combination, but my most recent efforts have stopped with client logs showing:
Tunnel status is now ‘connected’
‘Sending keep alive’
But pings back to the configured address on the Wireguard interface of 192.168.32.1 don’t show any hits.
A few other things, I did configure a firewall rule to allow the incoming port traffic (I think).
Hopefully I got rid of all the secret stuff here. This didn’t seem to export the peer info, not sure how to get that to export from the terminal, if its needed let me know.
# 2025-05-12 21:20:21 by RouterOS 7.18.2
# software id = BEVV-WS58
# model = E50UG
# serial number = XXX
add admin-mac=F4:1E:57:71:B9:89 auto-mac=no comment=defconf name=bridge
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add interface=wireguard1 list=LAN
/interface ovpn-server server
add mac-address=FE:07:57:F0:7D:95 name=ovpn-server1
/interface wireguard peers
add allowed-address=0.0.0.0/0 client-address=192.168.32.2/24 client-dns=\
192.168.32.1 client-endpoint=“XXPUBLIC_IPXX interface=wireguard1 name=\
iphone private-key=“XXPRIVATE1XX” \
public-key=“XXPUBLIC1XX
192.168.88.0
add address=192.168.32.1 interface=wireguard1 network=192.168.32.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.2 client-id=1:8:36:c9:80:d8:25 mac-address=\
08:36:C9:80:D8:25 server=defconf
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="allow WireGuard" dst-port=13231 \
protocol=udp
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip ipsec profile
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=America/New_York
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
