can someone help in how to setup
a wire guard VPN so i can connect my MT android app to my LTE device
thanks
a dump file below for reference
# 2024-05-29 09:26:22 by RouterOS 7.14.3
# software id = A2N8-******
# model = RBSXTR
# serial number = HG1********
add admin-mac=18:FD:******* auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] mac-address=18:FD:*******
set [ find default-name=ether2 ] mac-address=18:FD:*******
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=broadband use-network-apn=yes
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=broadband \
band=4 network-mode=lte sms-read=no
/ip hotspot profile
add name=dhcp ranges=192.168.88.100-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf interface=ether1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add comment=defconf interface=lte1 list=WAN
192.168.88.0
/ip cloud
set ddns-enabled=yes
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1,8.8.8.8 \
gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment=WINBOX connection-nat-state=dstnat \
connection-state=new connection-type="" dst-port=8291 protocol=tcp
invalid disabled=yes
disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=change-ttl chain=postrouting new-ttl=set:64 out-interface=lte1
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=vpn
/system clock
set time-zone-autodetect=no time-zone-name=America/Chicago
/system identity
set name=iPhone12
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.google.com
/system watchdog
set watch-address=1.1.1.1
/tool mac-server
/tool mac-server mac-winbox
