The situation is that I have a Site-to-Site Wireguard VPN between pfSense and hap ac3
I can ping the device at home if I set “interface=homevpnclient” but when I use “interface=bridge”, it timed out
[admin@MikroTik] /tool> ping 192.168.0.134 interface=bridge
SEQ HOST SIZE TTL TIME STATUS
0 192.168.0.134 timeout
1 192.168.0.134 timeout
2 192.168.0.134 timeout
3 10.100.2.1 84 64 127ms188us host unreac...
4 192.168.0.134 timeout
sent=5 received=0 packet-loss=100%
[admin@MikroTik] /tool> ping 192.168.0.134 interface=homevpnclient
0 192.168.0.134 56 63 161ms362us
1 192.168.0.134 56 63 286ms419us
sent=2 received=2 packet-loss=0% min-rtt=161ms362us avg-rtt=223ms890us
max-rtt=286ms419us
Home Network: 192.168.0.0/16
Mikrotik Network: 10.100.2.0/24
Configuration:
# may/20/2022 12:57:00 by RouterOS 7.2.3
# software id = Q9US-L2X7
# model = RBD53iG-5HacD2HnD
# serial number = F34E0F51C32B
add admin-mac=DC:2C:6E:13:64:D8 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=MikroTik-1364DC wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
ap-bridge ssid=MikroTik-1364DD wireless-protocol=802.11
/interface wireguard
add listen-port=13231 mtu=1420 name=homevpnclient
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=10.100.2.100-10.100.2.200
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
/interface wireguard peers
add allowed-address=192.168.0.0/16,10.15.210.1/32,::/0 endpoint-address=\
siwatsystem.com endpoint-port=51820 interface=homevpnclient \
persistent-keepalive=10s public-key=\
add address=10.100.2.1/24 interface=bridge network=10.100.2.0
add address=10.15.210.3/24 interface=homevpnclient network=10.15.210.0
/ip dhcp-client
add address=10.100.2.0/24 comment=defconf dns-server=10.100.2.1 gateway=\
10.100.2.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward dst-address=192.168.0.0/16 src-address=\
10.100.2.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add check-gateway=ping disabled=no distance=1 dst-address=192.168.0.0/16 \
gateway=10.15.210.1 pref-src=0.0.0.0 routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system clock
set time-zone-name=Asia/Bangkok
/tool mac-server
/tool mac-server mac-winbox
