WireGuard site-to-site VPN problem
I have read many posts about WireGuard VPN, but I still haven’t managed to succeed. I have two MikroTik routers with a WireGuard tunnel between them. From the local network of Router B, I have access to the local network of Router A. However, the reverse does not work. From the local network of A, I cannot access B. Router A is the server, and Router B is the client for WireGuard.
Site A
# 2025-09-09 22:31:38 by RouterOS 7.19.3
# software id = LA5Z-APGI
# model = C52iG-5HaxD2HaxD
# serial number = ******
add admin-mac=F4:1E:57:B2:E0:7E auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name="ether2-LAN TV"
set [ find default-name=ether3 ] name="ether3-LAN Server"
set [ find default-name=ether4 ] name="ether4-LAN Desk"
set [ find default-name=ether5 ] name=ether5-LAN
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20mhz configuration.mode=ap .ssid=hm55 disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz configuration.mode=ap .ssid=hm222 disabled=no \
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-WAN name=pppoe-out1 \
    use-peer-dns=yes user=*********
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=Wireguard
add name=default-dhcp ranges=192.168.0.100-192.168.0.254
add address-pool=default-dhcp interface=bridge lease-time=1h name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface="ether2-LAN TV"
add bridge=bridge comment=defconf interface="ether3-LAN Server"
add bridge=bridge comment=defconf interface="ether4-LAN Desk"
add bridge=bridge comment=defconf interface=ether5-LAN
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add comment=WAN interface=pppoe-out1 list=WAN
add comment=wireguard interface=wireguard1 list=Wireguard
/interface wireguard peers
add allowed-address=192.168.100.2/32 client-address=192.168.100.2/32 \
    client-endpoint=*** comment=j-phone interface=wireguard1 name=\
    j-phone private-key="*********" \
    public-key="***********"
add allowed-address=192.168.100.3/32 client-address=192.168.100.3/32 \
    client-endpoint=*** comment=t-phone interface=wireguard1 name=\
    t-phone private-key="************" \
    public-key="************"
add allowed-address=192.168.100.4/32 client-address=192.168.100.4/32 \
    client-endpoint=*** comment=comp-work interface=wireguard1 \
    name=comp-work private-key="************" \
    public-key="*************"
add allowed-address=192.168.100.5/32,192.168.1.0/24 client-address=\
    192.168.100.5/32 client-endpoint=*** comment=krushevec \
    interface=wireguard1 name=krushevec public-key=\
add address=192.168.0.1/24 comment=LAN interface=bridge network=192.168.0.0
add address=192.168.100.1/24 comment=Wireguard interface=wireguard1 network=\
    192.168.100.0
/ip dhcp-client
add comment=defconf interface=ether1-WAN
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.1 gateway=\
    192.168.0.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
add action=accept chain=input comment=wireguard dst-port=13231 protocol=udp
add action=accept chain=input comment="wireguard access" in-interface=\
    wireguard1 protocol=tcp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat out-interface=wireguard1
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway=wireguard1 \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Sofia
/system identity
set name=MR-Router
/tool mac-server
/tool mac-server mac-winbox
Site B
# 2025-09-09 22:26:53 by RouterOS 7.18
# software id = AVTH-E7CW
# model = LHGGM
# serial number = *********
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band=""
add listen-port=51820 mtu=1420 name=wg1
add name=default-dhcp ranges=192.168.1.100-192.168.1.254
add address-pool=default-dhcp interface=ether1 name=defconf
/port
set 0 name=serial0
/queue type
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set ether1 queue=fq-codel-ethernet-default
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
/interface ovpn-server server
add mac-address=FE:98:CB:A0:E2:45 name=ovpn-server1
add allowed-address=192.168.0.1/24,192.168.100.0/24 endpoint-address=\
    ********** endpoint-port=13231 interface=wg1 name=peer1 \
    persistent-keepalive=25m public-key=\
add address=192.168.1.1/24 comment=defconf interface=ether1 network=\
    192.168.1.0
add address=192.168.100.5 comment=wireguard interface=wg1 network=\
    192.168.100.5
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
    192.168.1.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan type=A
    invalid
add action=masquerade chain=srcnat out-interface=wg1
/ip hotspot profile
/ip ipsec profile
add dst-address=192.168.0.0/24 gateway=wg1 routing-table=main \
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Sofia
/system logging
add prefix=WG topics=wireguard,error,warning
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.bg.pool.ntp.org
/tool mac-server
/tool sniffer
set file-name=eee.log filter-interface=wg1
Have you seen (and followed) this great explanation:
From your config I think you are missing the /ip firewall filter rules on the forward chain.
Hello hm123,
after reviewing your configuration, I would suggest making adjustments on site B:
/ip address remove [find interface=wg1]
/ip address add address=192.168.100.5/24 interface=wg1 comment="wireguard"
/interface wireguard peers set peer1 allowed-address=192.168.0.0/24,192.168.100.0/24 persistent-keepalive=25
Try it out, and if it works for you, you can remove the src NAT for WireGuard on both MikroTiks A and B, because it's unnecessary as long as the routes are set up correctly. I would also add persistent-keepalive=25 on site A.
Site B (CLIENT for handshake).
  • address structure for wireguard needs /24 and proper network setting.
    add address=192.168.100.5/24 comment=wireguard interface=wg1 network=
    192.168.100.0
  • you have queueing and fastrack enabled, suggest you turn one of them off.
    I would turn the queuing off (disabled) as for a single subnet it makes no sense to me.
  • there is no point in masquerading that I can see for the wireguard interface.
    YOu have control of both ends and can properly setup firewall rules and routes for the needed traffic.
-add wireguard to interface list lan
add interface=wg1 list=LAN
-remove this firewall rule
and replace with
add chain=forward action=accept comment="internet traffic" in-interface-list=LAN \
out-interface-list=WAN
add chain=forward action=accept comment="local users out wireguard" \
src-address=192.168.1.0/24 out-interface=wg1
add chain=forward action=accept comment="remote users inbound"  in-interface=wg1 dst-address=192.168.1.0/24
add chain=forward action=drop comment="drop all else"
SITE A ( SERVER for handshake )
  • remove wireguard from list and list members and simply make wireguard member of LAN
    add comment=wireguard interface=wireguard1 list=LAN
I personally find putting all the client noise in wireguard settings as NOT helpful so a clean view would be as follows:
add allowed-address=192.168.100.2/32 comment=j-phone interface=wireguard1 \
add allowed-address=192.168.100.3/32 comment=t-phone interface=wireguard1 \
add allowed-address=192.168.100.4/32 comment=comp-work interface=wireguard1 \
add allowed-address=192.168.100.5/32,192.168.1.0/24 comment=krushevec \
    interface=wireguard1 public-key=\"*******************"
  • AN error is the config is having pppoe for wan termination but then having IP DHCP Client active.
    DISABLE ip dhcp client.
  • remove the forward chain rule.
    "defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
and replace with:
add chain=forward action=accept comment="local users to wireguard" \
src-address=192.168.0.0/24 out-interface=wireguard1
add chain=forward action=accept comment="remote users to wireguard" \
in-interface=wireguard1 dst-address=192.168.00/24
add chain=forward action=accept comment="relay in from device thru RA to RB"
in-interface=wireguard1 out-interface=wireguard1
  • REMOVE masquerade rule for wireguard interface it is not helpful here.
Thank you everyone. After all recommended changes now everything looks good. I still have to do complete test but will do it in few days.
