Hello everyone,
I have successfully setup Wireguard as site to user VPN and it is working perfectly, but now I want to connect a second site and I don’t want all the computers there to have Wiregurad.
I have one RB5009 as the main router on the main site, and hap ax lite as the second router. I’ve successfully setup the hap ax lite as client to the RB5009 and I can ping from the router and access other services that are on that network, but when I setup a route I cannot access anything from the computers connected on the hap ax lite. I’ve tried everything, firewall rules, NAT and what not, but no luck, I can’t route traffic to Wireguard. Any help that will move me in any direction is welcome. Thanks in advance!
add admin-mac=48:A9:8A:83:F0:2A auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik-83F02D \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
/interface wireguard peers
add allowed-address=192.168.0.0/24,10.10.0.0/24 endpoint-address=\
endpoint-port=13231 interface=wireguard1 \
192.168.88.0
add address=10.10.0.148 interface=wireguard1 network=10.10.0.148
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes
/ip dns static
"Allow Forwarding Traffic from WireGuard Interface" in-interface=\
wireguard1
"Allow Return Traffic from LAN to WireGuard" dst-address=192.168.0.0/24 \
src-address=192.168.0.0/24
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=accept chain=input dst-port=13231 protocol=udp src-address=\
192.168.0.1
add action=accept chain=forward dst-address=192.168.0.0/24 src-address=\
10.10.0.0/24
add action=accept chain=forward dst-address=10.10.0.0/24 src-address=\
192.168.0.0/24
add disabled=no distance=1 dst-address=192.168.0.0/24 gateway=wireguard1 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Skopje
/system logging
add topics=wireguard
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-dst-ip-address=192.168.0.0/24 filter-interface=all
