wireguard slow
I have an RB952 with default configuration. I am connecting the router to a wireguard server I have set up on a VPS. I have created a wireguard interface and wireguard peer. The router does the handshake with the server
Clients connected to the router are going to the internet through the wireguard interface and when i verify whatsmyip i get the server's ip. But the connection is extremely slow. I am able to connect to the Wireguard server from my phone on cellular network with fast connection.
what could be wrong on the configuration or what would i need to change?
2025-05-15 19:34:54 by RouterOS 7.18.2
software id = U13N-3S1V
model = RB952Ui-5ac2nD
serial number =
add admin-mac=CC:2D:E0:F3:08:61 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=
MikroTik-F30866 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto mode=
ap-bridge ssid=MikroTik-F30866 wireless-protocol=802.11
/interface wireguard
add comment=Ionos listen-port=51820 mtu=1420 name=wg0
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/routing table
add disabled=no fib name=wireguard
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wlan2
/interface wireguard peers
add allowed-address=0.0.0.0/0,::/0 endpoint-address=66.179.XXX.XXX
endpoint-port=51820 interface=wg0 name=Ionos persistent-keepalive=25s
preshared-key="KEY" public-key=KEY="
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=10.8.0.7/24 comment="Ionos VPN" interface=wg0 network=10.8.0.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade"
add action=masquerade chain=srcnat out-interface=wg0
add disabled=no dst-address=0.0.0.0/0 gateway=wg0 routing-table=wireguard
suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute"
dst-port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/routing rule
add action=lookup disabled=no src-address=192.168.88.0/24 table=wireguard
/system clock
set time-zone-name=America/Puerto_Rico
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
The hAP ac lite has only a single core weak CPU, so don’t expect more than a few tens Mbps WG performance.
That being said, maybe you can try adding some mangle to adjust the MSS to accommodate the reduced MTU:
/ip firewall mangle
add action=change-mss chain=forward comment="reduce MSS for WG" new-mss=1380 \
    out-interface=wg0 protocol=tcp tcp-flags=syn tcp-mss=1381-65535
/ipv6 firewall mangle
add action=change-mss chain=forward comment="reduce MSS for WG" new-mss=1360 \
    out-interface=wg0 protocol=tcp tcp-flags=syn tcp-mss=1361-65535
And you should put wg0 into the interface list WAN, that way you won’t need the separate masquerade rule anymore.
So if i use a computer, will it make difference seeing as it has more cpu and ram power?
In your current config, the router (with its single core 650MHz CPU) is one of the WireGuard peers, which means it has to perform all the encryption & decryption work for WG tunneled traffic passing through it and will be the bottleneck. Your powerful PC in the LAN doesn’t matter. Even if the 2nd peer at the other side is also a powerful device, it doesn’t matter.
If you want improved WG performance, your router should no longer be a WG peer and should only act as router for encrypted traffic. You then run the WG client on your more powerful PC and the PC acts as a WG peer and does the encryption/decryption. Of course, the downside is that your PC have to be powered on.
But even in that case, you’ll be limited by the 100Mbps fast ethernet ports of the hAP ac lite.
