I have working wireguard between phone and my home(AX3). Rasberry pi is connected to the AX3 thorough LAN. I can access to web GUI of Rasberry but IM not able to connect Rasberry thorough SSH. Do you know where could be problem?
Check firewall for blocked ports.
Esp. port 22, see if it is allowed from wireguard towards LAN.
Thank you for helping.
I have only one port open for wireguard which wireguard need. Do I need to create another filter rule or I can use one with more allowed ports?
Additional rule is easier for troubleshooting.
And for completeness: I am referring to firewall on the device where wireguard comes in, not where it passes through.
Not clear what you are trying to do. Nor do you provide a config.
If you can reach the raspberry pi, what is the problem?
Ok,
AX3 has 10.255.255.4 WG adress
Mobile phone has 10.255.255.4 WG adress
RPI has 192.168.1.3. local adress
When I log into AX3 from my phone I can see I loged in with IP 10.255.255.4.
But If I create rulle scr. adr. 10.255.255.4 dest. adr. 192.168.1.3. port 22 and the opposite I still can not login. Any advice please?
OK, I’m going to sit on the porch with anav now…
Contradicting info there.
Please provide export of config (minus usual sensitive stuff like serial, public key, …)
/export file=anynameyouwish ( minus router serial# and any public WANIP info or keys etc. )
Log deleted
(tip: please post between code quotes. MUCH easier for reading.
Those: [__ ])
Personally: why do have this ?
/interface detect-internet set detect-interface-list=WAN lan-interface-list=LAN wan-interface-list=WAN
I would remove that.
Your wireguard interface is not a member of any interface list. So it’s definitely not WAN nor LAN.
Either add it to a separate list (VPN might be a good option) and foresee a rule which allows forward from VPN to LAN.
Or add wireguard to LAN list.
First one has my preference.
But … you also have this rule:
add action=accept chain=forward dst-address=10.255.255.4 dst-port=22
protocol=tcp src-address=192.168.1.3
Should be the reverse.
I am sure anav will be a bit more detailed with his response ![]()
Wireguard is part of LAN. The log may not show it but WG is in LAN.
Yes, I see it now as well.
But there is one other thing. Adjusted my comment.
I also see now you are using some block list for port 22.
Sure you don’t have to add an IP address to the allowed list ?
I have reverse in Firewall. I do not know why is it not in log..
add action=accept chain=forward dst-address=192.168.1.3 dst-port=22
protocol=tcp src-address=10.255.255.4
Because there is no log action ?
what do you mean?
This rule does not have a log action.
So nothing will be written to log when it is used.
(1) Set to NONE ( known to cause funky issues )
(2) Personal preference set tcp syn cookies to NO.
(3) You can get rid of the default static DNS setting.
/ip dns static
UP TO THIS POINT THE CONFIG IS QUITE GOOD, then you fall into the trap of focusing on everything except just permitting ALLOWED traffic.
SO that usually ends up botching actual needed performance sooner or later and also a dogs mess trying to find issues.
Lean, efficient and simplify.
(4) Remove DDOS crap, youir router cannot prevent DDOS
(5) My understanding is that if you have queues, you can no longer use fastrack in forward chain. OKAY I see its disabled, thats good!
(6) Why do you reference a 192.168.4.X network in firewall rules when none exists on the hapax or hapac ??? I am going to assume that you simply forgot to add
192.168.4.0/24 to the allowed-addresses on the peer settings from the hapac. I should add 192.168.5.0/24 based on your routes as well.
What a mess.
/interface wireguard peers
add allowed-address=10.255.255.2/32,192.168.3.0/24,192.168.2.0/24,192.168.4.0/24,192.168.5.0/24 comment=
“HAP AC3” interface=wireguard1 public-key=
“yh5i1pgBdN5p8xLELfeDI=”
(7) To add to that mess why do you use firewall rules for two subnets coming through wireguard from hapac, that makes zeros sense to me??
or worse to itself… Need serious consideration not to be configuring a firewall if you dont know what you are doing and simply copying and pasting crap from somehwere!!
add action=accept chain=forward dst-address=192.168.4.0/24 src-address=
193.168.4.0/24
(8) YOu use forward chain rules for Port forwarding (destination nat) which is wrong, only the general allow rule for dst-nat is required in MT forward chain, and port forward rules are refined in the NAT rule set.
However you seem to want to hit the server from both internal address and from wiregard address. So why not just go direct to the LANIP of the server, no need for any port forwarding when coming locally or through wireguard. Also if you plan to use the WANIP of your router for INTERNAL users, and not just external users, then your dst nat rules will need more work.
By the way since you didnt identify the LANIP of the server, it was left blank!!
(9) Firewall rules are disorganized. You should group chains together so its easy to follow what has been done as ORDER counts within a chain.
/ip firewall address list
add address=192.168.1.X list=ADMIN { admin desktop wired }
add address=192.168.1.Y list=ADMIN { admin laptop wired }
add address=192.168.1.XY list=ADMIN { admin laptop wifi }
add address=192.168.1.DC list-ADMIN { admin smartphone }
add address=10.255.255.X list=ADMIN { admin remotely connecting via wg }
add address=192.168.2.X list=ADMIN { in the off chance you or the admin at the hapac needs sometimes to config router from there over WG etc. }
{input chain}
(default rules)
established,related,untracked
invalid
(admin rules)
add action=accept chain=input comment=Wireguard dst-port=13231 protocol=udp
add action=accept chain=input comment="allow admin access to router in-interface-list=LAN src-address-list=ADMIN
add action=accept chain=input in-interface-list=LAN dst-port=53 protocol=tcp
add action=accept chain=input in-interface-list=LAN dst-port=53 protocol=udp
add action=drop chain=input comment="drop all else" { LAST RULE to put in, ensure admin access rule prior }
{forward chain}
(default rules)
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes hw-offload=yes
connection-state=invalid
(admin rules)
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN comment="allow internet traffic"
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=accept in-interface=wireguard1 dst-address=192.168.1.0/24 comment="wg users to local LAN"
add action=accept src-address=192.168.1.0/24 out-interface=wireguard1 comment="local LAN to wg"
add action=drop chain=forward comment="drop all else"
add action=accept chain=forward in-interface-list=WAN dst-port=22 \
protocol=tcp to-addresses=???????
add action=accept chain=forward in-interface-list=WAN dst-port=22 protocol=\
If you are truly concerned about ddos, then use zerotier cloudflare trust tunnel, (only available in a container, unlike WG which is part of RoS, and not even in an options package, believe I have been asking) as this functionality prevents any exposure of your IP address !!! This is the way. Your router cannot stop ddos, and is the ISP up chain responsibility.
Hello Anav,
thank you very much for checking all my settings. I will read it very carefully and try to learn.
What should I please change?
Thank you very much again
add disabled=no dst-address=192.168.2.0/24 gateway=wireguard1 pref-src=“”
routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=192.168.3.0/24 gateway=wireguard1
pref-src=“” routing-table=main scope=10 suppress-hw-offload=no
target-scope=10
add disabled=no distance=1 dst-address=192.168.4.0/24 gateway=wireguard1
pref-src=“” routing-table=main scope=30 suppress-hw-offload=no
target-scope=10
add disabled=no distance=1 dst-address=192.168.5.0/24 gateway=wireguard1
target-scope=10
add disabled=no distance=1 dst-address=10.1.168.0/24 gateway=192.168.192.34
target-scope=10 vrf-interface=zerotier1
add disabled=no distance=2 dst-address=192.168.2.0/24 gateway=192.168.192.34
add disabled=no distance=2 dst-address=192.168.3.0/24 gateway=192.168.192.34
add disabled=no distance=2 dst-address=192.168.4.0/24 gateway=192.168.192.84
Unfortunately you have other routers now? in the mix and unknown one at .5, and you prefer ddos for nothing, so good luck.
Ive done all I can here.
