I have configured a wireguard tunnel. The peer on the other end is a wireguard instance running on Linode.
Sometimes after I reboot the router OR when I start it after it was shutdown abruptly because of a power cut, I start seeing these errors in the console. I have verified the public/private keys in winbox and in the configuration on the other peer. The keys match perfectly so this should not fail and yet it does. The other peer becomes unreachable and the only way I have found to fix it is to replace the keys on the mikrotik router and update the other peer. After this it works perfectly until I have to reboot the router.
Since, From the looks of it, The keys have not changed at all so I can’t figure out why the authentication keeps failing.
I think I have had this problem from 7.1beta4.
Has anyone else ran into these issues? Is there a permanent fix? or anything else I can do here? Is the dev team aware of this issue?
Please let me know if I can provide any thing to help debug this. Thank you
