WireGuard VPN - Handshake error
Good day everyone!
I used RB4011+RM router,having problem in connecting through Static of my ISP in my wireguard
I use the roadwarrior default configuration and I tried to connect in my ANDROID through the static IP of my ISP as my endpoint config in Android but there is a problem in HANDSHAKE ERROR returning “did not complete after 5 seconds”.
I can connect in my WireGuard inside my network through wifi but in my android mobile data carrier, I can’t connect returning that handshake error.
As I check in the firewall it’s hitting this rule but looks like it’s not returning the handshake connection
add action=accept chain=input comment="allow WireGuard" dst-port=13231 protocol=udp place-before=1
I also add to accept UDP traffic in SRCNAT and also accept forward traffic in the firewall but no luck still getting errors and not hitting those firewall rules that I add.
Idk what I missed, I hope someone can guide me and help me troubleshoot. :>
Funny that. I’m having exactly same problem. Followed https://help.mikrotik.com/docs/display/ROS/WireGuard to the letter.
WG interface set up, peer added, firewall rules as well (for local access I just added wg interface to LAN group).
I’m stuck right at the beginning, client (iphone wg app) attempts connection, but never gets to complete the handshake.
I can see the accept rule being hit, packet counters going up with every handshake packet, but that’s it.
I enabled wireguard logging on the router and the only message I’m seeing is:
input: in:pppoe-out1 out:(unknown 0), connection-state:new src-mac 42:8f:9d:7f:a1:67, proto UDP, A.A.A.A:4780->X.X.X.X:13231, len 176
@pulegium
best to start your own thread. It is not always certain the issue is related.
Post link here so we can find you.
Both:
post full config of your Mikrotik as well as setting of client device for wireguard part.
terminal: /export file=
Review export for public info (serial number, public IP, private/public key, … put something in place so we know it is there but we can not see what it was) then post between [__code] tags.
It can also help to have a small drawing of your network indicating how the router is connected to your ISP modem, other devices in between, … (piece of paper and pencil is good enough)
Hi @holvoetn, heres my config
# oct/15/2022 16:21:08 by RouterOS 7.5
# model = RB4011iGS+
add admin-mac=08:55:31:40:3D:0C auto-mac=no comment="defconf Converge" name=\
    88bridge
add comment="defconf New Lan" name=172bridge
add comment=":defconf PLDT" name=178bridge
add comment="defconf Server Network" name=sapnetwork_bridge
set [ find default-name=ether1 ] name=ether1-ConvergeBiz
set [ find default-name=ether2 ] arp=disabled
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface pppoe-client
add allow=chap,mschap1,mschap2 dial-on-demand=yes disabled=no interface=\
    ether2 keepalive-timeout=30 name=PLDTEnterprise user=IMAXS213
/interface wireguard
add listen-port=51820 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment=WIFI name=WIFI
/interface lte apn
add add-arp=yes interface=88bridge lease-time=52w1d name=defconfHOME
add add-arp=yes interface=178bridge lease-time=52w1d name=defconENT
add add-arp=yes interface=sapnetwork_bridge lease-time=52w1d name=defonserver
add name=home-dhcp ranges=192.168.88.20-192.168.88.254
add name=enterprise-dhcp ranges=192.168.178.10-192.168.178.254
add name=newlan ranges=172.16.0.20-172.16.1.254
add add-arp=yes address-pool=newlan disabled=yes interface=172bridge \
    lease-time=52w1d name=defconNewlan
/port
set 0 name=serial0
set 1 name=serial1
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=yes name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/routing table
add fib name=88_Subnet
add fib name=178_Subnet
add fib name=172_Subnet
add fib name=LAN1_TO_WAN1
add fib name=LAN2_TO_WAN2
add disabled=no fib name=use-WG
add disabled=no fib name=wg-iterf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,rest-api"
add bridge=88bridge comment=defconf88 ingress-filtering=no interface=ether4
add bridge=sapnetwork_bridge comment="defconf Server Network" \
    ingress-filtering=no interface=ether10
add bridge=88bridge ingress-filtering=no interface=ether5
add bridge=178bridge comment=defconf178 ingress-filtering=no interface=ether6
add bridge=178bridge ingress-filtering=no interface=ether7
set discover-interface-list=none
/ip settings
set max-neighbor-entries=8192 tcp-syncookies=yes
/ipv6 settings
add comment=defconf interface=88bridge list=LAN
add comment=defconf interface=ether1-ConvergeBiz list=WAN
add interface=ether2 list=WAN
add interface=178bridge list=LAN
add interface=PLDTEnterprise list=WAN
add interface=172bridge list=LAN
add interface=sapnetwork_bridge list=LAN
add interface=wireguard1 list=LAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=192.168.100.2/32 interface=wireguard1 public-key=\
    "TEST"
add address=192.168.88.1/24 comment=defconf interface=88bridge network=\
    192.168.88.0
add address=192.168.178.1/24 interface=178bridge network=192.168.178.0
add address=192.168.0.1/24 comment=defconf interface=sapnetwork_bridge \
    network=192.168.0.0
add address=172.16.0.1/23 interface=172bridge network=172.16.0.0
add address=192.168.100.1/24 interface=wireguard1 network=192.168.100.0
/ip cloud
set ddns-enabled=yes update-time=no
/ip dhcp-client
add comment=defconf interface=ether1-ConvergeBiz use-peer-dns=no
add add-default-route=no comment="defconf FOR CONVERGE" disabled=yes \
    interface=ether3 use-peer-dns=no
add address=172.16.0.0/23 dns-server=172.16.0.1 gateway=172.16.0.1
add address=192.168.0.0/24 dns-server=192.168.0.2 gateway=192.168.0.1 \
    netmask=24
    192.168.88.1
add address=192.168.178.0/24 dns-server=192.168.178.1 gateway=192.168.178.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.0.116 name=SAPSERVER ttl=1d5s
add address=192.168.0.117 name=HOSTSERVER ttl=1d5s
add address=192.168.178.122 name=SALESSERVER ttl=1d5s
add action=accept chain=input comment="allow WireGuard traffic" src-address=\
    192.168.100.0/24
add action=accept chain=input comment="allow WireGuard" dst-port=51820 log=\
    yes log-prefix=accepted_wg_con protocol=udp
add action=reject chain=forward comment="blck facebook" disabled=yes \
    layer7-protocol=block_facebook log-prefix=Block protocol=tcp reject-with=\
    tcp-reset src-address-list=!fb_aclist
add action=accept chain=forward comment="ALLOW PORT FORWARDING WEBSERVER" \
    connection-nat-state=dstnat disabled=yes dst-address=192.168.178.122 \
    dst-port=9991 in-interface=PLDTEnterprise protocol=tcp
add action=accept chain=input comment="defconf: accept ICMP after RAW" \
    protocol=icmp
    established,related,untracked
add action=accept chain=input src-address-list=allowed_to_router
    in-interface-list=!LAN log-prefix=NotLAN
    "defconf: accept all that matches IPSec policy" disabled=yes \
    ipsec-policy=in,ipsec
add action=fasttrack-connection chain=forward comment=\
    "defconf:FastTrack accept established,related Priority Sites" \
    connection-mark=priority-conn connection-state=established,related \
    disabled=yes hw-offload=yes
    connection-state=invalid
    "Drop tries to reach not public addresses from LAN" dst-address-list=\
    not_in_internet in-interface=88bridge log-prefix=!public_from_LAN \
    out-interface=!88bridge
    not_in_internet in-interface=178bridge log-prefix=!public_from_LAN \
    out-interface=!178bridge
    not_in_internet in-interface=sapnetwork_bridge log-prefix=\
    !public_from_LAN out-interface=!sapnetwork_bridge
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp \
    protocol=icmp
add action=drop chain=forward comment="defconf: drop bad forward IPs" \
    src-address-list=no_forward_ipv4
    dst-address-list=no_forward_ipv4
add action=accept chain=icmp comment="echo reply" disabled=yes icmp-options=\
    0:0 protocol=icmp
add action=accept chain=icmp comment="net unreachable" disabled=yes \
    icmp-options=3:0 protocol=icmp
add action=accept chain=icmp comment="host unreachable" disabled=yes \
    icmp-options=3:1 protocol=icmp
add action=accept chain=icmp comment=\
    "host unreachable fragmentation required" disabled=yes icmp-options=3:4 \
    protocol=icmp
add action=accept chain=icmp comment="allow echo request" disabled=yes \
    icmp-options=8:0 protocol=icmp
add action=accept chain=icmp comment="allow time exceed" disabled=yes \
    icmp-options=11:0 protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" disabled=yes \
    icmp-options=12:0 protocol=icmp
add action=drop chain=icmp comment="deny all other types" disabled=yes
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s
add action=add-dst-to-address-list address-list=ddos-target \
    address-list-timeout=10m chain=detect-ddos
add action=add-src-to-address-list address-list=ddos-attackers \
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s \
    protocol=tcp tcp-flags=syn,ack
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
    "browsing-con for Priority websites " connection-bytes=0-1000000 \
    disabled=yes dst-address-list=Priority dst-port=80,443 \
    new-connection-mark=priority-conn passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting comment="Priority TCP Pckt" \
    connection-mark=priority-conn disabled=yes new-packet-mark=priority_pckt \
    passthrough=no
add action=mark-connection chain=prerouting comment="ZOOM TCP" disabled=yes \
    dst-address-list=zoom_ip dst-port=80,443,8801,8802,5091 \
    new-connection-mark=tcp_zoom passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting comment="ZoomTCP Pckt" \
    connection-mark=tcp_zoom disabled=yes new-packet-mark=zoom_pckt \
    passthrough=no
add action=mark-connection chain=prerouting comment="ZOOM UDP" disabled=yes \
    dst-address-list=zoom_ip dst-port=3478,3479,8801-8810,20000-64000 \
    new-connection-mark=udp_zoom passthrough=yes protocol=udp
add action=mark-packet chain=prerouting comment="ZoomUDP Pckt" \
    connection-mark=udp_zoom disabled=yes new-packet-mark=zoom_pckt \
    passthrough=no
add action=mark-routing chain=prerouting comment="LAN1 TO WAN 1" disabled=yes \
    new-routing-mark=LAN1_TO_WAN1 passthrough=yes src-address-list=\
    "88 Network"
add action=mark-routing chain=prerouting comment="LAN2 TO WAN 2" disabled=yes \
    new-routing-mark=LAN2_TO_WAN2 passthrough=yes src-address-list=\
    "178 Network"
add action=accept chain=srcnat disabled=yes out-interface=PLDTEnterprise \
    src-address=192.168.100.1
add action=masquerade chain=srcnat comment="defconf: All masquerade" \
/ip firewall raw
add action=accept chain=prerouting comment=\
    "defconf: enable for transparent firewall" disabled=yes
add action=accept chain=prerouting comment="defconf: accept DHCP discover" \
    disabled=yes dst-address=255.255.255.255 dst-port=67 in-interface-list=\
    LAN protocol=udp src-address=0.0.0.0 src-port=68
add action=drop chain=prerouting comment="defconf: drop bogon IP's" \
    src-address-list=bad_ipv4
    dst-address-list=bad_ipv4 log-prefix=badipv4
    src-address-list=bad_src_ipv4
    dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment="defconf: drop non global from WAN" \
    in-interface-list=WAN src-address-list=not_global_ipv4
add action=drop chain=prerouting comment=\
    "defconf: drop forward to local lan from WAN" dst-address=192.168.88.0/24 \
    "defconf: drop forward to local lan from WAN" dst-address=\
    192.168.178.0/24 in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0 \
    protocol=udp
add action=jump chain=prerouting comment="defconf: jump to ICMP chain" \
    jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain" \
    jump-target=bad_tcp protocol=tcp
    "defconf: accept everything else from LAN" in-interface-list=LAN
    "defconf: accept everything else from WAN" in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop the rest"
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp \
    tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,syn
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,urg
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=syn,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=rst,urg
add action=drop chain=bad_tcp comment="defconf: TCP port 0 drop" port=0 \
    protocol=tcp
add action=accept chain=icmp4 comment="defconf: echo reply" icmp-options=0:0 \
    limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: net unreachable" \
add action=accept chain=icmp4 comment="defconf: host unreachable" \
add action=accept chain=icmp4 comment="defconf: protocol unreachable" \
    icmp-options=3:2 protocol=icmp
add action=accept chain=icmp4 comment="defconf: port unreachable" \
    icmp-options=3:3 protocol=icmp
add action=accept chain=icmp4 comment="defconf: fragmentation needed" \
    icmp-options=3:4 protocol=icmp
add action=accept chain=icmp4 comment="defconf: echo" icmp-options=8:0 limit=\
add action=accept chain=icmp4 comment="defconf: time exceeded " icmp-options=\
    11:0-255 protocol=icmp
add action=drop chain=icmp4 comment="defconf: drop other icmp" protocol=icmp
add action=drop chain=prerouting comment="Defconf: dropping ddos attacker" \
    dst-address-list=ddos-target src-address-list=ddos-attackers
/ip firewall service-port
set ftp disabled=yes
set sip disabled=yes
add comment=CONVERGE disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    192.168.1.254 pref-src="" routing-table=88_Subnet scope=30 \
    suppress-hw-offload=no target-scope=10
add comment="PLDT ENTERPRISE" disabled=no distance=1 dst-address=0.0.0.0/0 \
    gateway=PLDTEnterprise pref-src="" routing-table=178_Subnet scope=30 \
add comment="REROUTE 88" disabled=yes distance=1 dst-address=0.0.0.0/0 \
    gateway=PLDTEnterprise pref-src="" routing-table=88_Subnet scope=30 \
add comment="NEW LAN NETWORK" disabled=yes dst-address=0.0.0.0/0 gateway=\
    PLDTEnterprise routing-table=172_Subnet
add comment="REROUTE 178" disabled=yes distance=1 dst-address=0.0.0.0/0 \
    gateway=192.168.1.254 pref-src="" routing-table=178_Subnet scope=30 \
add comment=USE-WG disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    PLDTEnterprise pref-src="" routing-table=use-WG scope=30 \
/ip service
set telnet disabled=yes
set www port=89
set ssh disabled=yes
set www-ssl disabled=no port=449
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ip traffic-flow
set active-flow-timeout=5m interfaces=88bridge
/ipv6 firewall address-list
add address=fe80::/10 comment="defconf: RFC6890 Linked-Scoped Unicast" list=\
    no_forward_ipv6
add address=ff00::/8 comment="defconf: multicast" list=no_forward_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6 after RAW" \
    protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/16
    protocol=udp
add action=accept chain=input comment="defconf: accept IPSec AH" protocol=\
    ipsec-ah
add action=accept chain=input comment="defconf: accept IPSec ESP" protocol=\
    ipsec-esp
    src-address-list=no_forward_ipv6
    dst-address-list=no_forward_ipv6
add action=accept chain=forward comment="defconf: accept ICMPv6 after RAW" \
    protocol=icmpv6
    500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept AH" protocol=\
    ipsec-ah
add action=accept chain=forward comment="defconf: accept ESP" protocol=\
    ipsec-esp
    "defconf: accept all that matches IPSec policy" ipsec-policy=in,ipsec
    !LAN
/routing rule
add action=lookup-only-in-table comment=88_Subnet disabled=no src-address=\
    192.168.88.0/24 table=88_Subnet
add action=lookup-only-in-table comment=178_Subnet disabled=no src-address=\
    192.168.178.0/24 table=178_Subnet
add action=lookup-only-in-table disabled=no src-address=172.16.0.0/23 table=\
    172_Subnet
add action=lookup-only-in-table disabled=no src-address=192.168.100.2/32 \
    table=use-WG
add action=lookup-only-in-table disabled=no src-address=192.168.100.1/24 \
    table=wg-iterf
/system clock
set time-zone-name=Asia/Manila
/system clock manual
set dst-delta=+08:00 dst-end="jan/01/2029 00:00:00" dst-start=\
    "jan/01/2022 00:00:00" time-zone=+08:00
/system identity
set name=Graphic
/system resource irq rps
set sfp-sfpplus1 disabled=no
/system scheduler
add name=Reboot on-event="system reboot" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=sep/10/2022 start-time=08:00:00
/tool bandwidth-server
set enabled=no
/tool graphing interface
add allow-address=192.168.88.0/24 interface=88bridge store-on-disk=no
add allow-address=192.168.178.0/24 interface=178bridge store-on-disk=no
add interface=PLDTEnterprise store-on-disk=no
add interface=ether1-ConvergeBiz store-on-disk=no
/tool mac-server
/tool mac-server mac-winbox
Config of client device as well please.
Just to confirm (since it is not visible):
  • Public key of INTERFACE is what is used as public key for peer in wg app of client. yes/no ?
  • public key of client (on top of the wg app) is what is used as public key on peer side of mikrotik. yes/no ?
    But since it works internal, I assume those are ok.
  • you ARE sure that port is reachable from outside on your mikrotik ? Nothing on ISP side which could block that ? No port forwarding needed ?
Mikrotik Peer Config
    "m41ebBaNxzC3NPDdiYVcwU5gxC/+Z9lJRUpOdWuXdEE="
My Android WG Config
[Interface]
Address = 192.168.100.2/32
DNS = 8.8.8.8
ListenPort = 51820
MTU = 1420
PrivateKey =
[Peer]
AllowedIPs = 0.0.0.0/0, 192.168.100.2/32
Endpoint = MyISPStaticIP:51820
PersistentKeepalive = 40
PublicKey = UngymIi8GRngu2a1F+yy+V04RGp8Rj2r7lo3pupvZFk=
Yes, those you mention were right in my config. As I said I can connect in WG if I’m using the internal network through my WiFi using the WG IP interface 192.168.100.1 as an endpoint config
but using the external connection “mobile data” and I can’t connect if I use the MyISPStaticIP as the endpoint in the android config
I am not seeing anything obvious right now …
If you go to IP / Cloud, does it correspond to the static IP you are expecting ?
I am confused on your wan setup.
(1) (A) First you have pppoe setup which is where normally DHCP is done when connecting to ISP
(B) Then you have entries in IP DHCP Client?
(C) To top it off you reference two different etherports in this setting??
/ip dhcp-client
add add-default-route=no comment=“defconf FOR CONVERGE” disabled=yes
(3) Wireguard peer settings seem okay (as per holvoe ensuring keys match up properly)
(4) Slight mod to one of the firewall rules ( the firewall rules setup is a farce bloated unnecessarily complex , but thats just my opinion)
add action=accept chain=input comment=“allow WireGuard traffic” src-address=
192.168.100.0/24 in-interface=Wireguard1
(5) I would add two firewall rules to ensure you are allowing traffic as required…(if your intent was to reach subnets behind the router) and the internet!!
add chain=forward action=accept in-interface=Wireguard1 out=interface-list=LAN
add chain=forward action=accept in-interface=Wireguare1 out-interface-list=WAN
(6) What is with the accept rule in Masquerade rules…???
Fix it the first rule should either be.
add action**=masquerade** chain=srcnat disabled=yes out-interface=PLDTEnterprise
src-address=192.168.100.0/24
OR
add action=masquerade chain=srcnat disabled=yes out-interface=PLDTEnterprise
However in this case there is no need for a masquerade rule for wireguard clients as the default Masquerade source nat rule will handle your client to WAN traffic from wireguard.
Thus REMOVE this poorly configured rule…
(7) What is the purpose of this rule??
PLDTEnterprise pref-src=“” routing-table=use-WG scope=30
Are you telling me you have subnet users that will go out your android phone for internet???
(8) Similarly what the heck is the purpose of this routing rule…
table=wg-iterf
First of all, there is no route I could see with routing-rule of wg-iterf ???
Secondly, why would you need to control traffic coming out of the wireguard tunnel, its already tied to a specific interface and you can visit your lan subnets or go out local internet without issue.
I got two WANs that Ether1 is currently in CGNAT of ISP router that ether2 or PLDT in PPPoE was the static…
Sorry for some out-of-this-world configuration that came from experimenting. Thank you I’ll take your correction/advice/correction. I’ll give feedback after some workloads get done.
The public IP I get in >IP/Cloud are from my ISP 1 which is behind NAT, so the remote connection won’t work for ISP1, I just want to use the Public Static IP of ISP2 which I want to make it work.
@holvoetn @anav
I just solved my problem by removing the IP routes of WAN 1 and adding the default routes of my WAN 2
add dst-address=0.0.0.0/0 gateway=PLDTEnterprise routing-table=main
which has static IP, now I can connect using mobile data when connecting to the static WAN IP.
I usually use the routing rules to separate two subnets to each ISP, the reason I put general routes is the device (Router) won’t get internet.
