MAIN ROUTER A ( server peer for wireguard handshake )
/routing table
add disabled=no fib name=use-WAN2
/ip route ( minimum )
add distance=2 check-gateway=ping dst-address=0.0.0.0/0 gateway=pppoe-out1
add distance=4 dst-address=0.0.0.0/0 gateway=WAN2-gateway-ip
add dst-address=0.0.0.0/0 gateway=WAN2-gateway-ip routing-table=use-WAN2
/ip route ( better - recursive - checks connection to internet is actually up, not just connection to ISP )
add distance=2 check-gateway=ping dst-address=0.0.0.0/0 gateway=1.0.0.1 scope=10 target-scope=12
add distance=2 dst-address=1.0.0.1/32 gateway=pppoe-out1 scope=10 target-scope=11
Now all traffic will go to WAN1, and if WAN1 is not available traffic will move to WAN2 and will go back to WAN1 when it is functional.
Ensure you use the standard masquerade sourcenat rule as well.
/ip firewall mangle ( to ensure traffic coming in on WAN2 goes back out WAN2 )
add chain=input action=mark-connection connection-mark=no-mark
in-interface=WAN2 new-connection-mark=incomingWAN2 passthrough=yes
add chain=output action=mark-routing connection-mark=incomingWAN2
new-routing-mark=use-WAN2 passthrough=no
Ensure on the forward chain fasttrack rule you add the following:
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
connection-state=established,related connection=mark=no-mark
Finally to deal with the bug, we need a trick destination nat rule to ensure wireguard traffic does NOT go back out WAN1
add action=dstnat chain=dst-nat in-interface=WAN2 dst-address-type=local dst-port=wireguardport protocol=udp to-address=staticWAN1-ip
The idea being, the router will assume all wireguard traffic that wants to exit WAN1, will be un-detinatted to wan2…
Basically the same for Router B.
Main differences - no need for input chain rule for handshake.
Allowed peers need endpoint address of WAN2 on router A, and wireguard port and persistent keep alive set.
Would add another mangle rule on router B as first rule to ensure MTU handling…
add action=change-mss chain=forward comment=“Clamp MSS to PMTU for Outgoing packets” new-mss=clamp-to-pmtu out-interface=wireguard1 passthrough=yes protocol=tcp tcp-flags=syn
Best bet is to post complete config for review after an attempt to incorporate method of choice.
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys etc. )
