here is the “obsfucated and truncated” config, I changed ports, names or deleted lot of lines, from FW rules, VLANs,.. which I thought would not be necessary or related to this issue (e.g. communication between vlans, DHCP, IP pools, logs, etc..). If something will be missing, please let me know.
by RouterOS 7.3beta40
model = RouterBOARD 750G r3
add admin-mac=xx:xx:xx:xx:xx auto-mac=no frame-types=
admit-only-vlan-tagged mtu=1500 name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether3 ] comment=“VLAN1 - Management”
set [ find default-name=ether4 ] comment=TRUNK
set [ find default-name=ether5 ] comment=TRUNK
/interface ovpn-server
add name=ovpn-in1 user=xxxxxxxx
Interface" user=xxxxxxx1
/interface wireguard
add listen-port=12345 mtu=1492 name=wireguard1
/interface vlan
add interface=bridge name=VLAN1-test6 vlan-id=1
add interface=bridge name=vlan10-LAN vlan-id=10
add interface=bridge name=vlan11-test7 vlan-id=31
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=LAN include=all name=“test ipsec”
/interface lte apn
/ip ipsec mode-config
add connection-mark=NordVPN-mark name=NordVPN responder=no src-address-list=
NordVPN use-responder-dns=no
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256,aes-192,aes-128
hash-algorithm=sha256
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha384 name=
NordVPN
/ip ipsec peer
add address=xxx.xxx exchange-mode=ike2 name=NordVPN profile=NordVPN
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 pfs-group=modp2048
add auth-algorithms=sha256 name=home pfs-group=modp2048
add name=NordVPN pfs-group=none
add name=VPN-OpenVPN ranges=192.168.254.100-192.168.254.105
add name=vlan13-test5 ranges=192.168.42.100-192.168.42.150
/port
set 0 name=serial0
/ppp profile
/queue type
add kind=pfifo name=OpenVPN pfifo-limit=250
/queue interface
set ovpn-in1 queue=OpenVPN
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/system logging action
add bridge=bridge comment=defconf frame-types=
admit-only-untagged-and-priority-tagged interface=ether2 pvid=10
admit-only-untagged-and-priority-tagged interface=ether3 pvid=11
admit-only-untagged-and-priority-tagged interface=ether4 pvid=40
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
set discover-interface-list=none protocol=“”
/ipv6 settings
/interface bridge vlan
add bridge=bridge tagged=bridge,ether5 vlan-ids=10
add bridge=bridge tagged=bridge,ether5 untagged=ether4 vlan-ids=
add bridge=bridge tagged=bridge,ether5 vlan-ids=100
/interface ovpn-server server
set auth=sha1 certificate=OpenVPN-Server cipher=aes256 enabled=yes port=1234
protocol=udp require-client-certificate=yes tls-version=only-1.2
/interface wireguard peers
add allowed-address=192.168.99.100/32 interface=wireguard1 public-key=
“xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”
add address=192.168.42.1/24 interface=vlan13-test5 network=192.168.42.0
add address=192.168.99.1/24 interface=wireguard1 network=192.168.99.0
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 list=NotPublic
add address=10.0.0.0/8 comment=RFC6890 list=NotPublic
add address=100.64.0.0/10 comment=RFC6890 list=NotPublic
add address=127.0.0.0/8 comment=RFC6890 list=NotPublic
add address=169.254.0.0/16 comment=RFC6890 list=NotPublic
add address=172.16.0.0/12 comment=RFC6890 list=NotPublic
add address=192.0.0.0/24 comment=RFC6890 list=NotPublic
add address=192.0.2.0/24 comment=RFC6890 list=NotPublic
add address=192.168.0.0/16 comment=RFC6890 list=NotPublic
add address=192.88.99.0/24 comment=RFC3068 list=NotPublic
add address=198.18.0.0/15 comment=RFC6890 list=NotPublic
add address=198.51.100.0/24 comment=RFC6890 list=NotPublic
add address=203.0.113.0/24 comment=RFC6890 list=NotPublic
add address=224.0.0.0/4 comment=RFC4601 list=NotPublic
add address=192.168.200.0/24 comment=“TESTVLAN host” list=NordVPN
add address=192.168.0.0/16 list=NOT_for_NordVPN
add address=10.0.0.0/8 list=NOT_for_NordVPN
add address=172.16.0.0/16 list=NOT_for_NordVPN
add disabled=yes list=ALL
add address=192.168.30.0-192.168.30.148 list=NordVPN
add address=192.168.99.100 list=NordVPN // this is WG client marked to go to NordVPN tunnel
add action=drop chain=forward comment=“DROP not public IP reach LAN”
in-interface=ether1 log=yes log-prefix=DROP-ALL-PRIVATE-IP-IN
src-address-list=NotPublic
add action=drop chain=forward comment=“Drop all packets from local network to
internet which should not exist in public network” dst-address-list=
NotPublic log=yes log-prefix=DROP-ALL-PRIVATE-IP-OUT out-interface=ether1
add action=accept chain=forward comment=“Test one way FW rule between VLAns”
connection-state=established,related log-prefix=
ACCEPT-ESTABLISHED-RELATED
add action=accept chain=input comment=
“Accept established and related packets” connection-state=
established,related
add action=accept chain=input comment=“Wireguard VPN” port=12345 protocol=udp
add action=accept chain=forward comment=“Wireguard allow internet”
in-interface=wireguard1 out-interface=ether1
add action=accept chain=input comment=“WireGuard allow DNS” dst-address=
192.168.99.1 in-interface=wireguard1 port=53 protocol=udp
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid log=yes log-prefix=
DROP-ALL-INVALID-PACKETS-FORWARD
add action=drop chain=input comment=“Drop invalid packets” connection-state=
invalid log=yes log-prefix=DROP-ALL-INVALID-PACKETS-INPUT
“Drop all packets which are not destined to routes IP address”
dst-address-type=!local log-prefix=DROP-ALL-NOT-DESTINATED-TO-ROUTES
“Drop all packets which does not have unicast source IP address” log=yes
log-prefix=DROP-ALL-INPUT-NO-UNICAST-SRC-IP src-address-type=!unicast
add action=drop chain=forward log=yes log-prefix=
DROP-ALL-FORWARD-NO-UNICAST-SRC-IP
“Drop new connections from internet which are not dst-natted”
connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=drop chain=forward comment=“BLOCK ALL?” log=yes log-prefix=
DROP-ALL-FORWARD
/ip firewall mangle
add action=passthrough chain=prerouting disabled=yes dst-address-list=ALL
log=yes src-address-list=NOT_for_NordVPN
add action=mark-connection chain=prerouting comment=
“Mark packets for NordVPN” dst-address-list=!NOT_for_NordVPN log=yes
new-connection-mark=NordVPN-mark passthrough=yes src-address-list=NordVPN
add action=change-mss chain=forward comment=
“lowering MTU due to NordVPN issues” new-mss=1300 passthrough=yes
protocol=tcp tcp-flags=syn tcp-mss=1301-65535
add action=masquerade chain=srcnat comment=“defconf: masquerade”
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip ipsec identity
add auth-method=eap certificate=“” eap-methods=eap-mschapv2 generate-policy=
port-strict mode-config=NordVPN peer=NordVPN policy-template-group=
NordVPN username=xxxxxxxxxx
/ip ipsec policy
set 0 proposal=home
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=
0.0.0.0/0 template=yes
/ppp secret
add name=openvpn-user1 profile=“OpenVPN - clients” service=ovpn
