Wireguard vpn
I have established vpn tunnel with wireguard
If I set route
Dst. Address 0.0.0.0/0 and Gateway wireguard1:
DST-ADDRESS GATEWAY DISTANCE
0 As+ 0.0.0.0/0 wireguard1 1
then all my traffic from all ports (ether2, ether3, …) on Mikrotik Router is routed through VPN.
So wireguard and vpn works ok.
How can I route through wireguard only interface ether3 or only specific device with static ip?
Regards, ALes
Two ways, use of routing rules or use of mangles,
Either way you will need to add a table and an IP route.
Thanks for info. I managed it to work. Regards, ALes
