Wireguard wgsd-client plugin
Hello Guys
Feature request for Wireguard in Mikrotik
Maybe some of you know wgsd-client,
What is it ?
-wgsd-client is responsible for keeping peer endpoint configuration up to date.
-It retrieves the list of configured peers, queries wgsd for matching public keys, and then sets the endpoint value for each peer if needed.
-This client is intended to be run periodically via cron or similar scheduling mechanism.
-It checks all peers once in a serialized fashion and then exits.
Here the source for it in go lang
https://github.com/jwhited/wgsd/tree/master/cmd/wgsd-client
This way whould be possible to use wireguard on mikrotik to connect two networks behind cgnat point to point.
This wgsd-client will keep up peer informations retrieved from a registry Coredns server that helps point A to connect to point B directly
Here some more information about it for the most entusiasts:
https://www.jordanwhited.com/posts/wireguard-endpoint-discovery-nat-traversal/
Thanks to jordan whited for his study.
Grettings to all.
Interesting, but unlikely to be directly supported in RouterOS. Problem is, it’s just one possible solution, nothing standard, so why implement this one and not something else?
On the other hand, the idea is extremely simple, something that could be easily done with script, if there were required functions. All you need is ability to resolve SRV records and work with data, and base32/64 conversions. AFAIK current RouterOS scripting has none of those, but I’d definitely support request to add them, because it could be useful for many other things.
In case you don’t need exactly this and only something like this, you can replace dns with http and then it could be doable even with what RouterOS scripting can do now. And even if you do need compatibility with this, you could easily add http as kind of proxy for RouterOS clients.
