Hello, I’m experimenting with Wireguard on 7.2 and noticed some strange issues: Mikrotik sends too big mss and requests to lower it later with icmp unreachable.
- Server has MSS = 1420.
Mikrotik configuration
/interface wireguard
add listen-port=51820 mtu=1420 name=wireguard1
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=-snip- endpoint-port=51820 interface=wireguard1 persistent-keepalive=15s public-key="RvCiqqxCP3PD43ttnsoRNJsvDzs1Rb/IrRguzcpp6G4="
However, when I try to make a tcp connection this very Mikrotik sends mss 1460, that fails to pass server’s 1420:
20:10:13.877083 IP -snip-55118 > 151.101.65.67.https: Flags [S], seq 3727460725, win 65535, options [mss 1460,nop,wscale 6,sackOK,TS val 3017899 ecr 0], length 0
resulting in
20:10:13.952138 IP 151.101.65.67.https > -snip-: Flags [P.], seq 1449:2897, ack 518, win 285, options [nop,nop,TS val 3508144898 ecr 3017968], length 1448
20:10:13.952146 IP -snip- > 151.101.65.67: ICMP -snip- unreachable - need to frag (mtu 1420), length 176
This issue needs mangle rule to work correctly, however, maybe other methods exists?
Any client side MTU on wireguard1 is effectively ignored, packets are still mss=1460. On the other side, bumping wireguard interface to 1500 on server works, but with horrible performance, as everyhing is fragmented to hell.
