I haven’t personally used policy routing yet in RouterOS 7, but even for RouterOS 6 this doesn’t make sense. You are telling your router to take any packet that is received on ether1 and immediately send it back out ether1 again instead of delivering it like normal. So your gateway (ISP?) is going to send the packet back to you and you are going to send it back to the gateway and so on in a loop until the TTL finally expires. And you seem to be missing the routing mark to set in the mark routing mangle rule, so even that loop will not be happening right now.
Alright cool yeah just ignore the routing stuff, I redid the thread so I can just figure out why wireguard isn’t functioning. Mangle stuff I can deal with way later since I have it working fine in my core and I don’t think I should have to use mangle for a simple wireguard setup.
So yeah if you know anything about wireguard glance at the new thread data and see if anything is missing or incorrect.
Tested with windows wireguard client since ya know, logging isn’t needed for Tik’s. Handshake fails on the client, the Tik see’s the packets coming in but has an unknown(0) for out interface. Seems the Tik doesn’t know what to do with the wireguard packets.
I have an SSTP tunnel up on the CHR and it’s working fine. But tryin to bring up a wireguard tunnel for testing and potential port over from SSTP.
I haven’t used wireguard before, but I was able to create a functional wireguard tunnel between my two MikroTik devices at home (both 7.1beta4) following this tutorial:
It is up and running and passes traffic just fine. The only part that wasn’t super obvious is that I didn’t have to manually specify a private key - leaving it blank and clicking OK or Apply will result in a proper private key being auto generated.
Yeah what that guy does in the video is how mine are setup. It’s not negotiating the actual key exchange according to the windows client logs so my CHR is apparently refusing to allow keys to be exchanged and checked. And yes it is configured correctly.
