I have 2 pcs of RB532’s@400 MHz and 4 R52 cards and I try to use it in dual nstreme configuration with 5GHz-turbo mode.
With the above config in table, im getting asymmetric 4-5/27-30 Mbit tcp traffic, i cant figure out why could be this happened.
Also I have a plan, as i build a pair of wireless bridges from 2.5 GHz P4 PC’s, with 2-2 R52 cards using them in dual nstreme, 5GHz turbo mode, exact framing. What is yours opinion, what throughput I can squeeze out from this link? I would like to reach 45 Mbps full duplex tcp traffic…
The PC should work fine. I have a link with an AMD 2.5Ghz on one side and a VIA 533Mhz on the other side and I get 45mbps full duplex in turbo mode. I use a 2.4ghz card for the TX and a 5.8Ghz card for the RX.
I only run it in the G mode(20mhz) now, I don’t need that much speed. But it’s nice to know it’s there if I do need it.
It’s no record holder at under a mile but one end of the link is inside the building shooting through 1" glass with a mirror tint. The antennas are Pac Wireless panels 19dbi 2.4Ghz and 24dbi 5.8Ghz.
