Hi, the problem is with access list the following…
When i put a new client on access list, all other clients that was registered on the same wlan … immediatly disconnect; after a few seconds all client return to connect to wlan …
i’m using routerboard 333 routerOs version 3.3 and r52 …
Thanks, but with RuterOs 2.9xx did not works as 3.xx this is a bug of 3.xx.
I can’t think that every time that i add one new station the other 30 station and pppoe-client registred go down !!
for me this is abnormal …
Well, you could as well look at the new/changed rule to decide if you have to disconnect one/some/all clients (so only those actually affected by the change in the ruleset).
But I agree that is has been like it is now all the time.
Thanks at all, i discovered what been the problem !!
now i explain the problem …
when I add a new customer, I would add the mac address in the access list but before applying the configuration add comment by the name of the customer and save comment, then apply the configuration of new mac-address
with the old firmware everything works well, with the new version all customers are disconnected with the addition of a new mac-address and commentary simultaneously
the problem is the comment saved before apply the configuration of new-client, if i add the comment after add the client all works.
