I have an open network with a 532A and 2 2.4GHz antennas, the network its open and uses hotspot and pppoe to auth, the problem is that next to my tower they build a school and i have a bunch of mobile devices connected to the wlans and the performance of the 532 goes down..!
i use only routerboard, ubiquiti and some tranzeo CPE’s equipments.. its there any way i can make a wild card and let connect only my cpe’s by vendor MAC??
ie:
00:15:6D:XX:XX:XX ?.. or make a connect-list with this?..i block at least 30 new macs connected to the tower everyday.. i have a list of over 300 macs on access list who are unable to forward or auth.
They work great for the amount of clients they are handling, and i love this RB because on radio is on the front and the other in the back, so i think it gets less noise between each radio compared to the one you get for example in a 433X.
im not 100% sure. about 5-6-7 boxes with new one. (is it 50 in each box? not sure) And a bounch of used… its 1 euro pallet about 170cm high in total. (but used ones is stacked on top without spacing, protection etc, so its a lot… im sure a lot of em dont work eather) it maybe also some cases with 502, and own prodused 502, with transformator and more power to expansion card. Im not sure. I have to much of this old stuff if really interested. i can count.
PS, i also have 700 old NMP cards (new) + some boxes with used ones. (nice to cpe, and hotspot’s)
we produce our own metal frame, antennas and plastic, and this old stuff dont fit to this annymore. it was faced out around 2007 i think.
