Wireless Access Point and Client
Hi All,
Can anyone advise if any of the following are capable of being a wireless access point and also connect to a wireless network at the same same using the in built hardware?
hAP lite
mAP 2n
RB951G-2HnD
AP can connect to another AP, and serve other client as AP, when WDS feature is used.
If you have MikroTik network, then it can be easily configured on every listed device in your post.
