wireless accessing Mikrotik: NeighborViewer YES, winbox NO..
I can log onto my mikrotik hotspot router wirelessly through Neighbor viewer, but cannot via winbox. winbox detects it…after a very long wait…but when i try to log on via MAC it gives error : “router disconnected”
I get errors & unsuccessful trying to log on via IP also… could it be some kind of firewall or port issue? what port should I be trying on?..where/how to configure / allow such a port… if need be…
Mikrotik novice here…answer like I’m 5yrs old…
what versionare you using, maybe try to upgrade if it is not newest one
Winbox uses 8291 port for 2.9 versions.
Are you able to access router via null modem (console) cable ?
using 2.9.27
if you still ahve problems, make your configuration backup and do /system reset and then try. that must be configuration problem
to finish this thread, I upgraded to latest mikrotik and latest winbox and built hotspot from scratch now everything is working fine.
