Hi all,
Judging by the forum I’m not the only one who’s having DHCP issues… but anyway. I have a fairly simple setup which doesn’t work with Wi-Fi and VLANs.
Device:
hAP ac2, ROS 7.7
Goal:
To have “Main” (VLAN ID 33) and “Guest” (VLAN ID 10) VLANs, with one having TVs and cell phones etc in “Guest” and having laptops in “Main”. Firewall will come later because I just want to have this fixed first. More specifically, I want to assign wireless clients to different VLANs based on their MAC addresses (yes, I know about RADIUS and how insecure this is etc). Two SSIDs are not really an option since area is quite big and idea of having to come up closer to the router to access different network is beyond ridiculous for me. Also, I want uniform SSID for both ranges.
The Problem:
Using Wireless ACL never really sets VLAN tag on a device – it’s visible on DHCP Leases tab as “offered”, but bonding never happens. There are some DHCP errors in system log after I enabled explicit logging, suggesting (I’ve seen it here in similar topics) that final communication between client and AP doesn’t happen, hence address is never accepted – but that’s just my assumption.
Config:
# feb/09/2023 17:41:59 by RouterOS 7.7
# software id = NMRU-ISKF
# model = RBD52G-5HacD2HnD
# serial number = 1234567890
add admin-mac=18:FD:74:30:1A:B4 auto-mac=no comment=defconf ingress-filtering=no name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] comment="WAN port"
set [ find default-name=ether5 ] comment=TV
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=etsi disabled=no distance=\
indoors frequency=auto installation=indoor mode=ap-bridge ssid=Cactus wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=etsi disabled=no \
distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=Cactus wireless-protocol=802.11
/interface vlan
add comment="Main VLAN, data access" interface=bridge name=vlan1 vlan-id=33
add comment="Guest VLAN, Internet access only" interface=bridge name=vlan2 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=GUEST
add name=WIRELESS
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=guest_pool ranges=192.168.10.10-192.168.10.254
add name=main_pool ranges=192.168.33.10-192.168.33.254
add address-pool=guest_pool interface=vlan2 lease-time=1m name=guest
add address-pool=main_pool interface=vlan1 lease-time=1m name=main
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 pvid=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 pvid=33
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2 pvid=33
/interface bridge vlan
add bridge=bridge tagged=bridge untagged=wlan1,wlan2,ether5 vlan-ids=10
add bridge=bridge tagged=bridge untagged=wlan1,wlan2 vlan-ids=33
add interface=vlan2 list=GUEST
add interface=wlan1 list=WIRELESS
add interface=wlan2 list=WIRELESS
/interface wireless access-list
add comment=lenovo disabled=yes interface=WIRELESS mac-address=E0:XX:XX:XX:XX:XX vlan-id=33 vlan-mode=use-tag
add comment=asus disabled=yes interface=WIRELESS mac-address=A4:XX:XX:XX:XX vlan-id=33 vlan-mode=no-tag
add comment=chrome disabled=yes interface=WIRELESS mac-address=4C:XX:XX:XX:XX:XX vlan-id=33 vlan-mode=use-tag
add comment="Default all clients to guest VLAN" disabled=yes interface=WIRELESS vlan-id=10 vlan-mode=use-tag
add address=192.168.10.1/24 comment="VLAN for guests" interface=vlan2 network=192.168.10.0
add address=192.168.33.1/24 comment="Main VLAN" interface=vlan1 network=192.168.33.0
/ip dhcp-client
add add-default-route=yes comment=defconf interface=ether1
add address=192.168.10.0/24 comment="Guest VLAN network" gateway=192.168.10.1
add address=192.168.33.0/24 comment="Main VLAN network" gateway=192.168.33.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related \
hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether1
add disabled=no dst-address=0.0.0.0/0 gateway=ether1 routing-table=main suppress-hw-offload=no
Wireless ACL is disabled now since I hardcoded all wireless interfaces to use VLAN 33. Once I enable this and remove PVID from the bridge, wireless network is broken – no one can get an IP.
What I have tried:
- enabling/disabling ingress filtering on the bridge;
- different combinations of tagged/untagged ports for the bridge;
- assigning IP to a client manually;
- changing VLAN admit policy for bridge ports;
I’m out of ideas, but I do suspect something is wrong with Wi-Fi settings (or the bridge?
)… I would greatly appreciate any help!
Thank you
