What kind of SNMP info that we can get from RouterOS .. Specialy about the wireless AP feature.
Can we got a per remote station SNR (local and remote) condition ?
I can got it from Orinoco AP-1000 and it’s very usefull. Unfortunately the product is discontinued.
Used to be played with snr.sourceforge.net for monitoring AP-1000 and AP-500
I think it’ll be great if there is any docs about RouterOS’s specific OIDs and the meanings of each OIDs
You can execute ‘print oid’ command on respective menu levels (like /interface wireless registration-table print oid). It will give you information about available OIDs.
It is freeware and it gives me a website with all the stats for my users.
simple to set up and use.
Each user has a simple Queue set up then use the “Queue-> simple->print oid” command to get a list of the OID’s. put the OID’s in the SNMPView config file. run the program and it even puts the users names in the table for me.
