WIRELESS AP TO AP 100 MB
Hello to all
I have the following problem:
3 mikrotik 433 with a link WDS in V5.6 in connect this one to 2 B/G 40turbo.
I manage to come in every end to 45-50 MB but I need 100
NV2 is not compatible with link WDS.
please can u indicate myself like can to connect 3 Mikrotik to 100mb?
Thank you
Regards
give us more details, post your registration table. what signal do you get tx/rx, and what rate is it connected at? b/g will not get you any much faster, you need 802.11n for faster.
i dont know i can print config in temrinal to apste here sorry.
Help me please i need conect these mikrotik 100mb.
regards
go to the “registration table” tab and post a picture of that.
The signal is ideal. You are already connected at the best rate, 108Mbit. For 802.11g standard this is good. Your maximum speed can only be around 70Mbit with this mode.
For more, you need 802.11n and Nv2.
What configuration do you have there? Why do you use WDS?
Because not it forms other one to connect 3 MKT.
I need nv2 but since I connect them 3MKT with nv2 and 802.11n
can u indicate myself little by little?, since you see I am new in this of links wifi
Thank you very much.
Regards
please make a network drawing why you need AP mode in all routers.
can you maybe use one AP and two station WDS bridged together? if you use station wds, you will be able to use nv2
ok do it with 1 AP an 2 Station and dont transmite name.
i think with these transfere 70 -90 mb
one moment i tel u now
thx
Hello to all.
I can do the link between 3 MKT with 1 AP bridge and 2 station.
I can add the protocol NV2 but it not be formed to obtain 100MB or 80 MB from Station 1 to station 2. Have I to create some route in bridge?
I have a DHCP server assigned in AP and the station as DHCP Client.
The channel I disturb 40
That mas can form in order that on having done badwich test it obtains from 80 to 100 MB between the station???
Regards
Hello to all.
Regards
