[quote=“syadnom”]
ap-bridge <> station-bridge is still what you need to ptp.
[/quote]
But what is the established practice to connect two ap-bridge radios?
ap-bridge to ap-bridge means full WDS, which can be somewhat troublesome. You can do it, but if it is a ptp link then ap-bridge to station-bridge is best
as far as rstp, I guess I don’t see where the loop is coming in. If you could provide some more details as to where you are having a layer2 segment loop… Anyway, rstp wont hurt, its just some overhead so you can leave it on if you are concerned.
Give three APs “A”, “B” and “C”, where A has bridged ptp links to both B and C; B has bridged ptp links to both A and C; and C has bridged ptp links to both B and C; then there is a cycle in which a broadcast packet (for example) could be forwarded from A, to B, to C, to A, etc. (RSTP detects the cycle and choose of the three two-way links above to disable.)
Ok, I see now. If it were me, I wouldn’t bridge the A-B, B-C, C-A links. I would run 3 separate L2 segments and route with OSPF. If that isn’t an option, RTSP will be fine with the following notes: RTSP keeps the current route until it fails. If one links gets slower, RTSP wont know/care. It’s a one way failover, meaning that once it fails over, it will stay that way until it fails again.
If you are putting in multiple links for redundancy, you might want to look at something more than rstp
Redundancy is the idea. In fact what we want is a 5GHz backhaul mesh, except I’m concerned that using a mesh rather than a bridge would result in problems where we use non-MT switches, which do not support the HWMP+ protocol. For example, suppose two APs are linked by both radio backhaul, and by Ethernet through a non-MT switch. Would HWMP+ detect the loop?
HWMP+ would detect the loop. Problem is that HWMP+ is a link state, not a link quality mesh routing protocal. So if a link is up at all, HWMP+ will consider it 100%. What I meant was that if you have 2 links, you might want to utilize the combined throughput. Redundancy is nice, but double capacity w/ failover is better.
like doing OSPF to load balance two links…
I would > love > to set up OSPF, since our backbone will soon be too large to be a single broadcast domain. A working configuration is going to take some trial and error though, as my networking experience is limited (background in software development).
You can setup the links with OSPF and then run an EoIP tunnel between. You can bridge the EoIP into the L2 on both sides. you get the throughput gains and maintain a L2 link.
