Wireless basic infrastructure setup with omnitik
I have a question, very general wireless infrastructure:
If I want to send a wireless signal from point A to point B, and in B I want to put a OmniTIK,
which is better:
  • (Point A) SXT Bridge ----> (Point B) SXT Bridge Station to receive + OmniTIK for AP
  • (Point A) SXT Bridge Station —> (Point B) OmniTIK
In the first option I make a point to point connection, and the OmniTIK take internet from ether
In the second option, the SXT is a OmniTIK station. OmniTIK receives the signal through wlan and distributes it to the rest of their clients
I need only to know wich is the better way to the max bandwith? A or B? (I don’t need software configs)
What is the model that is commonly used?
Can you make a draw from your setup?
It is for me not clearly
ok, thank you very much.
I believe that too. I had doubts because placing OmniTIK close to SXT create interferences, and the final data rate from point A, to end clients, it was not good. The only solution I found is to separate as much as possible the antennas frequencies.
