Hoping somebody here can help.
I have the following config:
VLANS 70,77, 700,701, and 777.
VLAN 70 is my LAN/management traffic that I'm hoping to establish a wireless connection to from one Netbox 5 ax (AP mode) to another in station bridge mode.
I've configured wireless config settings for the ssid that is setup to use datapath on VLAN 70, Bridge has all VLANs in one lan_bridge and traffic connects properly when wired into eth1 plugged in to my switch on a trunk port (eth1 is trunk port on the netbox, which only has one ethernet port). I can make the wireless connection, which seems to be working because then I start getting RSTP errors and winbox drops my connection. So, I unplug the wired connection.... and then cannot connect over the wifi port to the second netbox 5. If I plug the netbox into the already configured powerbox trunk port and then wire myself into the same vlan there, I can once again see the netbox. I also see registration on both ends showing up, but again cannot pass traffic wirelessly across the two devices. I feel like there's something funky going on with the tagged/trunk ports, but can't quite figure out where I've gone wrong.
They are all setup with static IPs. Main is 10.2.70.231, and EH1 is 10.2.70.232. Connecting via wifi on my computer to the AP (main) allows me to connect on the interlink SSID and I can ping all devices on that side of the wireless bridge and pass traffic from my computer wirelessly to those, however there is no access to the station bridge side.
Connecting via ethernet to the powerbox that has a trunk port connected to the station bridge netbox gives me access to the powerbox and netbox on that side, but I can't get across to the other side.
Configs are below. The main AP is configured via capsman but I tried to take it off and manually configure with no change. The station bridge is manually configured with wifi.
MAIN NETBOX:
add frame-types=admit-only-vlan-tagged name=lan_bridge vlan-filtering=yes
/interface wifi
# managed by CAPsMAN 04:F4:1C:AD:EE:F0%vlan70-LAN, traffic processing on CAP
# mode: AP, SSID: KPX-TrustedInterlink, channel: 5745/ax
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap \
disabled=no
/interface vlan
add interface=lan_bridge name=vlan70-LAN vlan-id=70
add bridge=lan_bridge frame-types=admit-only-vlan-tagged interface=ether1
add bridge=lan_bridge frame-types=admit-only-vlan-tagged interface=wifi1 \
pvid=70
/interface bridge vlan
add bridge=lan_bridge tagged=lan_bridge,ether1,wifi1 vlan-ids=\
1,70,77,99,700-701,777
/interface ovpn-server server
add mac-address=FE:FA:EB:17:34:FC name=ovpn-server1
/interface wifi cap
set certificate=request discovery-interfaces=vlan70-LAN enabled=yes
add address=10.2.70.231/24 interface=vlan70-LAN network=10.2.70.0
set servers=1.1.1.1
/ip ipsec profile
add disabled=no dst-address=0.0.0.0/0 gateway=10.2.70.1 routing-table=main
/ipv6 nd
set [ find default=yes ] advertise-dns=yes
/system clock
set time-zone-autodetect=no time-zone-name=US/Pacific
/system identity
set name=NetBox5ax-Main
EH1 (station bridge)
/interface vlan
add interface=lan_bridge name=Guest_Wireless vlan-id=701
add interface=lan_bridge name=LVP-TrustedWiFi vlan-id=700
add interface=lan_bridge name=LVP_Cams vlan-id=77
add interface=lan_bridge name=LVP_LAN vlan-id=70
add interface=lan_bridge name=Plant_Controller vlan-id=777
add include=all name=LAN
add name=MGMT
/interface wifi channel
add band=5ghz-ax disabled=no frequency=5180,5200,5220,5240 name=5GHZ::UNII-1 \
width=20mhz
add band=5ghz-ax disabled=no frequency=5745,5765,5785,5805,5825 name=\
5GHZ::UNII-3 width=20mhz
add band=5ghz-ax disabled=no frequency=\
5180,5200,5220,5240,5745,5765,5785,5805,5825 name=5GHZ::NON-DFS width=\
20mhz
add band=2ghz-ax disabled=no frequency=2412,2437,2462 name=2GHZ::AUTO width=\
20mhz
/interface wifi datapath
add disabled=no name=datapath-Trusted vlan-id=700
add disabled=no name=datapath-guest vlan-id=701
add disabled=no name=datapath-Interlink vlan-id=70
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=Trusted-Security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=Guest-Security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=\
Interlink-Security
/interface wifi configuration
add channel=2GHZ::AUTO country="United States" datapath=datapath-Trusted \
datapath.vlan-id=700 disabled=no mode=ap name=cfg-2Ghz security=\
Trusted-Security ssid=KPX-TrustedWiFi-2Ghz
add channel=5GHZ::NON-DFS country="United States" datapath=datapath-Trusted \
datapath.vlan-id=700 disabled=no installation=outdoor mode=ap name=\
cfg-5Ghz security=Trusted-Security ssid=KPX-TrustedWiFi-5Ghz
add country="United States" datapath=datapath-guest datapath.vlan-id=701 \
disabled=no installation=outdoor mode=ap name=cfg-GUEST security=\
Guest-Security ssid=KPX-GuestWiFi
add channel=5GHZ::NON-DFS channel.frequency=\
5180,5200,5220,5240,5745,5765,5785,5805,5825 country="United States" \
datapath=datapath-Interlink disabled=no installation=outdoor mode=\
station-bridge name=cfg-Interlink security=Interlink-Security \
security.authentication-types=wpa2-psk,wpa3-psk ssid=\
/interface wifi
set [ find default-name=wifi1 ] configuration=cfg-Interlink \
configuration.mode=station-bridge disabled=no \
add bridge=lan_bridge tagged=ether1,lan_bridge,wifi1 vlan-ids=\
add address=10.2.70.232 interface=LVP_LAN network=10.2.70.232
set allow-remote-requests=yes servers=1.1.1.1
/system identity
set name=Netbox-EH1
