HI,
I use 2 SXT Sixpack Point 2 Point Bridge mode, But my speed is 50MBPS Only, I attached also my client device screenshot. Plz anybody can tell me is there i need to change anything for more speed ?[attachment=0]client.jpg[/atthttp://forum.mikrotik.com/download/file.php?mode=view&id=23991achment]
The information you have provided isnt too detailed, but you can check the following:
- Any queues applied on the devices?
- Wireless band you are using (A/N), Wireless Frequency Bandwidth (20/40/80Mhz)
- Limit set on Bandwidth test client?
- No,
- N , Wireless Frequency Bandwidth (20Mhz)
- No
