I need to connect with my router to an AP and bridge it to ethernet interfaces. The AP is not MikroTik, so I cant set up EoIP or WDS, I dont even have access to setting that thing. I set it up MikroTik that connects to the AP like this (RB433):
add name=lan
add bridge=lan interface=wlan1
add bridge=lan interface=ether1
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=key \
supplicant-identity="" unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=\
******** wpa2-pre-shared-key=********
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country="czech republic" \
disabled=no frequency=2462 mode=station-pseudobridge security-profile=key \
ssid=a*****
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=lan
In this configuration, I get IP over DHCP both on MikroTik and my NTB connected to ether1. But when I try to ping anything over the wireless conection, it timeouts.
I tried alse station and station-bridge as wireless mode.
Is it possible to make it work this way? If yes, how can I set it up, if not, why?
Thank you.
