Hello guys can somebody help me? i’m new to mikrotik and i would like to bridge 2 RBs. can somebody tell me how to bridge these 2 wireless intrefaces?
thank you in advance.
oh thanks a lot. another question. is it possible to create 2 scripts, the first with the settings for the AP device and the other one for the wds station??? in order to make it simplier to install?
You can write CLI configuration commands to Notepad [TextEdit] file,
all the lines you configure in the Terminal for AP and station-wds
save them as something.rsc
Then use this scripts during the installation.
