Hello
I upgraded my Router(RB2011) Yesterday to 7.1 Yesterday and everything seemed ok everything was working but in the evening when i tried switching off some of my servers from my Android Phone I realized I could not reach anything on LAN.
Looking for anyone who has had this issue to assist resolve it seems to be related to Wireless on the router I have an AP in the other rooms and from there it works only the wireless on the router.
is there a privacy setting somewhere that could cause this?
ADD:
Internet is Okay
All was well on 6.49
Is it posible to post the config of the Mikrotik device ?
(/export hide-sensitive file=anynameyouwish)
Below
# dec/09/2021 10:31:28 by RouterOS 7.1
# software id = 82QS-JV7P
# model = 2011UiAS-2HnD
# serial number = 762D0733BACB
add comment="LAN Bridge" name=home protocol-mode=none
set [ find default-name=ether1 ] disabled=yes
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether3 ] comment="Switch LAN"
set [ find default-name=ether4 ] comment="Desk Cable LAN"
set [ find default-name=ether5 ] comment=LAN-Homelab
set [ find default-name=ether6 ] advertise="10M-half,10M-full,100M-half,100M-f\
ull,1000M-half,1000M-full,10000M-full,2500M-full" disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] comment=WANURSA name=ether8-URSA
set [ find default-name=ether9 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full comment=\
GPONCPE name=ether9-Faiba
set [ find default-name=ether10 ] disabled=yes poe-out=off poe-priority=5
set [ find default-name=sfp1 ] disabled=yes
/interface pppoe-client
add comment="GPON Faiba" disabled=no interface=ether9-Faiba max-mtu=1500 \
name=JTLFaiba user=
set 6 vlan-mode=fallback
set 7 vlan-mode=fallback
set 8 vlan-mode=fallback
set 9 vlan-mode=fallback
set 10 vlan-mode=fallback
set 12 vlan-mode=fallback
add comment=WAN name=WAN
add comment=LAN name=LAN
add comment=Phone name=LTE
/interface lte apn
set [ find default=yes ] ip-type=ipv4
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed mode=dynamic-keys name=home \
supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] allow-sharedkey=yes area=1 band=2ghz-b/g/n \
channel-width=20/40mhz-XX comment=LAN country=kenya disabled=no distance=\
1 frequency=2417 installation=indoor max-station-count=50 mode=ap-bridge \
multicast-helper=dhcp name=wireless security-profile=home ssid=twitwi \
wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
/interface wireless nstreme
set wireless comment=LAN
/interface wireless manual-tx-power-table
add name=home ranges=172.20.100.30-172.20.100.60
add address-pool=home interface=home lease-time=10h name=home
/port
set 0 name=serial0
/queue simple
add burst-limit=10M/20M burst-threshold=10M/20M burst-time=5s/5s disabled=yes \
max-limit=10M/20M name=queue1 target=ether5
/snmp community
set [ find default=yes ] addresses=172.20.100.0/25 name=
add bridge=home ingress-filtering=no interface=wireless
add bridge=home ingress-filtering=no interface=ether4
add bridge=home ingress-filtering=no interface=ether5
add bridge=home ingress-filtering=no interface=ether3
set discover-interface-list=!none
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=ether8-URSA list=WAN
add interface=home list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=wireless list=LAN
add interface=ether9-Faiba list=WAN
add interface=ether3 list=LAN
add interface=JTLFaiba list=WAN
add list=WAN
add address=172.20.100.1/26 comment=Home interface=home network=172.20.100.0
/ip cloud
set ddns-update-interval=3h update-time=no
/ip dhcp-client
add add-default-route=no comment=GPONFaibaCPE interface=ether9-Faiba \
use-peer-dns=no use-peer-ntp=no
add add-default-route=no comment=URSALink interface=ether8-URSA script="/ip dn\
s static remove [find where name=cellrouter.lan]\r\
\n:if (\$bound=1) do={\r\
\n /ip dns static add name=cellrouter.lan address=\$\"gateway-address\"\r\
\n}\r\
\n" use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=172.20.100.39 client-id=1:ee:15:2e:6b:e8:8a comment=" Phone" \
mac-address=EE:15:2E:6B:E8:8A server=home
add address=172.20.100.34 client-id=1:b4:47:f5:85:e1:12 comment=Telly \
mac-address=B4:47:F5:85:E1:12 server=home
add address=172.20.100.32 client-id=1:a4:50:46:56:13:ab comment="redmi job" \
mac-address=A4:50:46:56:13:AB server=home
add address=172.20.100.37 client-id=1:24:ee:9a:a8:a6:c4 comment=\
"Work Laptop Wireless" mac-address=24:EE:9A:A8:A6:C4 server=home
add address=172.20.100.38 client-id=1:0:68:eb:62:1f:83 comment=\
"Work Laptop Cable" mac-address=00:68:EB:62:1F:83 server=home
add address=172.20.100.30 client-id=1:0:c:29:f9:69:d2 comment=NewPlex \
mac-address=00:0C:29:F9:69:D2 server=home
add address=172.20.100.42 client-id=1:74:de:2b:10:2b:b4 commentLaptop \
mac-address=74:DE:2B:10:2B:B4 server=home
add address=172.20.100.43 client-id=1:8c:a9:82:99:b3:6a comment=KidsLaptop \
mac-address=8C:A9:82:99:B3:6A server=home
add address=172.20.100.40 client-id=1:0:c:29:ab:40:97 comment=HomeAssistant \
mac-address=00:0C:29:AB:40:97 server=home
add address=172.20.100.41 client-id=1:d2:62:8:cb:9e:9 comment=WorkPhone \
mac-address=D2:62:08:CB:9E:09 server=home
add address=172.20.100.44 client-id=1:32:6a:5f:3:92:15 comment=\
" New Phone" mac-address=32:6A:5F:03:92:15 server=home
add address=172.20.100.31 client-id=1:0:c:29:2c:26:a2 comment=VPNPC \
mac-address=00:0C:29:2C:26:A2 server=home
add address=172.20.100.35 client-id=\
ff:29:26:c6:1:0:1:0:1:28:fa:de:4:0:c:29:26:c6:1 comment=OpenMediaVault \
mac-address=00:0C:29:26:C6:01 server=home
add address=172.20.100.48 client-id=1:0:c:29:53:44:61 comment=\
DomainControler/CertServer mac-address=00:0C:29:53:44:61 server=home
add address=172.20.100.0/26 dns-server=172.20.100.1 gateway=172.20.100.1
set allow-remote-requests=yes cache-max-ttl=2d max-concurrent-queries=1000 \
max-concurrent-tcp-sessions=200 max-udp-packet-size=1024 \
query-server-timeout=3s servers=\
8.8.8.8,8.8.4.4,208.67.220.220,208.67.222.222,1.1.1.1
/ip firewall address-list
add address=172.20.100.2-172.20.100.254 list=allowed_to_router
add address=762d0733bacb.sn.mynetname.net disabled=yes list=MyDDNS
add address=139.162.40.38 disabled=yes list=plex
add action=accept chain=input comment="default configuration" \
add action=accept chain=input src-address-list=allowed_to_router
add action=drop chain=input connection-state=invalid
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=forward comment="Established, Related" \
add action=drop chain=forward comment="Drop invalid" connection-state=invalid \
log=yes log-prefix=invalid
add action=accept chain=forward disabled=yes dst-address-list=plex dst-port=\
80,443 protocol=tcp
add action=drop chain=forward disabled=yes out-interface-list=WAN \
src-address=172.20.100.34
add action=drop chain=input comment=winboxdrop dst-port=8291 \
in-interface-list=WAN protocol=tcp
add action=masquerade chain=srcnat comment=WAN out-interface-list=WAN
add action=masquerade chain=srcnat comment=GPON disabled=yes out-interface=\
JTLFaiba
add action=masquerade chain=srcnat comment=Faiba disabled=yes out-interface=\
*E
add action=src-nat chain=srcnat disabled=yes out-interface=*E to-addresses=\
192.168.0.10
add action=dst-nat chain=dstnat disabled=yes dst-address=197.232.121.32 \
dst-port=4040 protocol=tcp to-addresses=172.20.100.30 to-ports=32400
/ip firewall service-port
set ftp disabled=yes
add comment=Faiba disabled=no dst-address=0.0.0.0/0 gateway=JTLFaiba
add comment=Cellular disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
ether8-URSA
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh address=172.20.100.0/26 disabled=yes port=2200
set www-ssl certificate=home tls-version=only-1.2
set api disabled=yes
set winbox address=172.20.100.0/26
set api-ssl address=172.20.100.0/26 certificate=home tls-version=only-1.2
/ip traffic-flow
set enabled=yes
/lcd
set default-screen=interfaces enabled=no time-interval=daily touch-screen=\
disabled
/lcd interface
set sfp1 disabled=yes
set ether1 disabled=yes
set ether2 disabled=yes
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
set ether10 disabled=yes
set wireless disabled=yes
/lcd interface pages
set 0 interfaces=ether8-URSA,ether9-Faiba
/lcd screen
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 4 disabled=yes
set 5 disabled=yes
/snmp
set enabled=yes trap-generators=""
/system clock
set time-zone-autodetect=no time-zone-name=Africa/Nairobi
/system identity
set name=home
/system logging
add action=disk prefix=critical topics=critical
add action=disk prefix=warning topics=warning
add action=disk prefix=error topics=error
add action=disk prefix=info topics=info
add action=disk prefix=debug topics=debug
add action=disk prefix=poe topics=poe-out
/system ntp client
set enabled=yes
/system ntp client servers
add address=216.239.35.0
add address=162.159.200.123
add address=time.google.com
add address=2.ke.pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool graphing interface
add
/tool mac-server
/tool mac-server ping
set enabled=no
Maybe one of the following Paramters is the Problem on the Wireless-Interface…
Can you maybe temperary deactivate them and Test ?
wmm-support=enabled
not sure will check
I removed the wireless from the bridge then returned it and now everything works
any idea what this would be?
The export looks like the wireless isn’t in the bridge.
it was
/snmp community
Yup… Missed it on my phone.
Sorry to reopen but issue is Back.
Had a situation where my router was booting ok but it was not offering any service and so i did a reset. restored from the last backup. The issue came back the “solution” did not resolve.
It presents as devices connected to the mikrotik wireless iinterface cant connect to LAN Devices include SMB RDP and web consoles.
RB version is 7.1.5
# mar/29/2022 08:00:14 by RouterOS 7.1.5
# serial number =
add comment="LAN Bridge" name=home protocol-mode=stp
set [ find default-name=ether8 ] comment=WANURSALink
GPONCPE
add comment="GPON Faiba" disabled=no interface=ether9 max-mtu=1500 name=\
JTLFaiba user=P
/interface lte apn
set [ find default=yes ] comment=Default eap-methods="" \
management-protection=required mode=static-keys-required \
supplicant-identity=MikroTik
add authentication-types=wpa2-psk comment=DefaultHome disable-pmkid=yes \
eap-methods="" mode=dynamic-keys name=Home supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n bridge-mode=disabled \
channel-width=20/40mhz-XX comment="LAN Bridge" country=kenya disabled=no \
distance=indoors frequency=2452 hw-retries=10 installation=indoor \
max-station-count=100 mode=ap-bridge name=wireless security-profile=Home \
ssid=twitwi tx-power=7 tx-power-mode=all-rates-fixed wireless-protocol=\
802.11 wps-mode=disabled
set wireless comment="LAN Bridge"
add address-pool=home interface=home lease-time=1d name=home
/port
set 0 name=serial0
/queue simple
/snmp community
set [ find default=yes ] addresses=25 name=pablo
/user group
add name=group1 policy="local,reboot,read,test,winbox,password,web,!telnet,!ss\
h,!ftp,!write,!policy,!sniff,!sensitive,!api,!romon,!dude,!tikapp,!rest-ap\
i"
add bridge=home fast-leave=yes interface=wireless
/ip settings
/ipv6 settings
add interface=ether8 list=WAN
add interface=ether9 list=WAN
add list=WAN
add address=LAN.1/26 comment=Home interface=home network=LAN.0
/ip cloud
/ip dhcp-client
add add-default-route=no comment=GPONFaibaCPE interface=ether9 use-peer-dns=\
no use-peer-ntp=no
add add-default-route=no comment=URSALink interface=ether8 script="/ip dns sta\
\n:if (\$bound=1) do={/ip dns static add name=cellrouter.lan address=\$\"g\
ateway-address\"}" use-peer-dns=no use-peer-ntp=no
add address=LAN.0/26 dns-server=LAN.1 gateway=LAN.1
1.1.1.1,208.67.222.222,8.8.8.8,8.8.4.4,208.67.220.220
add address=LAN.2-LAN.254 list=allowed_to_router
add address=139.162.40.38 list=plex
add action=accept chain=input disabled=yes src-address-list=allowed_to_router
disabled=yes log=yes log-prefix=invalid
80,443 protocol=tcp
src-address=LAN.34
JTLFaiba
*E
192.168.0.10
add comment=Faiba disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
JTLFaiba pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
ether8
/ip service
set ssh address=LAN.0/26 disabled=yes port=2200
set www-ssl certificate=home disabled=no port= tls-version=only-1.2
set winbox address=LAN.0/26
set api-ssl address=LAN.0/26 certificate=home disabled=yes \
/ip traffic-flow
set enabled=yes
/lcd
set enabled=no touch-screen=disabled
/snmp
/system clock
/system identity
set name=home
/system logging
/system ntp client
set enabled=yes
set enabled=no
add
/tool mac-server
set enabled=no
