Wireless cards die after a week or so
Good Day,
I would like to find out what could be causing wireless cards to die, after about a week or so?
It does not completly die, the card is still usable, but with only a fraction of it’s transmit power.
Everytime I replace the card, I can get -75 signal, but after about a week of operation my signal drops down to -82.
Nothing on the system changes in this period.
Any help would be greatly appreciated
what is your location is near you a GSM tower; I have the same problem after COSMOTE have upgrade their tower what card are you using; what is the distance of the link ?
Hi Thanks for the quick response
I am located in Botswana, I am at least 1km from the nearest GSM cell tower, I am started out using R52-H card, that is no longer working correctly, then started using SR2, which is now also not transmitting at it’s full tx power even though it is set at default.
I am going to try a restore default configuration on the card and see what that does.
Oh I am using an omni.
[EDIT]
Reset default configuration on the interface has had no effect. Still does not have the tx power that it did when I installed the card!!
You might be experiencing damages caused electrostatic discharge. You need to ground the omni antenna properly and also run a ground wire along the length of the antenna. There was a post in this forum where this issue was extensively discoursed about two years ago but I cannot find the post anymore.
I found the link. http://forum.mikrotik.com/t/wireless-card-recieve-blows-issue/7930/1
The solution proposed by Gerard is what you need. It works better than charms.
Hi again,
Thanks for the link, same exact issue, as it has only happened when there was rain in the area…now that I come to think of it.
No lightning, just rain, so must be ESD issue.
Pitty the Manufacturer does not put a warning label on the antenna.
It’s wierd though, all my home made antenna’s omni ±9dbi work 100% even through weather, this is the only one I have purchased, and I have been through 3 wireless cards in 3 months.
Think I will just go to sectors from here, same me in the long run :slight_smile:
Thanks again
I had the same issue you had using an sr2 fried the card after a while. installed the grounding wire as gerald purposed and haven’t lost a card sence. However I have an omni up using an Xr2 without the wire going up the side and it has been up for months without issue. ( but i beleive the xr2 does not have the diversity chip thus the reason it does not blow) But its never a bad idea to put a grounding wire up the side of antenna to ground it from static discharge.
