Hi there,
I guess I’m missing something … There is a bit of a chaos on 5GHz around my flat so I decided to define a manual channel list for this frequency band. Otherwise, I have dropped connections as the Mikrotik stays in the lower channels on 5GHz where recently showed up a few more wifi netowrks.
I thought I understood how to define a channel by https://en.m.wikipedia.org/wiki/List_of_WLAN_channels#5_GHz_(802.11a/h/j/n/ac/ax)
However, as soon as I try to define a channel with 40MHz or 80MHz, the wireless module complains by “in scan-list unsupported channel: chYY”.
This is my wireless config:
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=20/40mhz-XX country=germany disabled=no frequency=auto hide-ssid=yes mode=\
ap-bridge name=[...] scan-list=5GHz ssid=[...] station-roaming=enabled vlan-id=99 wireless-protocol=802.11 wps-mode=\
disabled
set [ find default-name=wlan1 ] band=2ghz-onlyn country=germany default-forwarding=no disabled=no frequency=auto hide-ssid=yes mode=\
ap-bridge name=[...] ssid=[...] station-roaming=enabled vlan-id=66 wireless-protocol=802.11 wps-mode=disabled
And these channels I tried to define with the result of the above error:
List 5GHz
- channel 62 / 5310.000 / 40.000 / 5GHz-A / Ce
- channel 140 / 5700.000 / 40.000 / 5GHz-only-AC / disabled
(and I played with a few more; also activated indoor frequencies in the wireless settings with no result)
Does anyone know a detailed how-to on this for German 5GHz channels or an exemplary config? Thanks a lot!
