please i have a problem connecting from a wireless client to a Ap Bridge my configurations are likefollow and signal is -85
base
interface wireless> pr
0 name="wlan1" mtu=1500 mac-address=00:18:E7:0B:BA:CB arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="CREATIVEAK" mode=ap-bridge ssid="CREATIVEAK" area=""
frequency-mode=superchannel country=japan antenna-gain=0 frequency=2327
band=2.4ghz-b scan-list=2327 rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=static wds-default-bridge=none
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
client
0 name="wlan1" mtu=1500 mac-address=00:18:E7:0B:BA:C1 arp=enabled
radio-name="0018E70BBAC1" mode=station-wds ssid="CREATIVEAK" area=""
band=2.4ghz-onlyg scan-list=2327 rate-set=default
54Mbps
